Intel i7 3770K Εντυπώσεις/Μετρήσεις
LazyGreek
  • Replies 842
Τελικα το ματι κερδισε την ποσοτητα.
8GB G.Skill DDR3 PC3-19200 2400MHz TridentX Series CL10 (10-12-12-31) Dual Channel kit
Oχι ΚΑΙ αυτο?
Pre-tested by G.Skill in the motherboards listed below.
  • Μαχιμους Ζητα77 ΤΖΕΝΕ
  • ASUS P8Z77-V DELUXE
  • ASUS P8Z77-V PRO
  • ASUS P8Z77-V LX
  • ASUS P8Z77-V LE
  • ASUS SABERTOOTH Z77
  • Gigabyte G1.Sniper 3
  • Gigabyte GA-Z77X-UD5H
  • Gigabyte GA-Z77X-D3H
  • Gigabyte GA-Z77X-UD3H
  • Gigabyte GA-Z77-D3H
  • MSI Z77A-GD65
  • MSI Z77A-GD55
  • MSI Z77A-G45
  • ASRock Z77 Professional
  • ASRock Z77 Extreme6
  • Biostar TZ77XE4
μπραβο οι samsung...
- 2400MHz (11-11-11-28 2N) @ 1.50v
και προτιμησες τις πιο ακριβες 8γιγα μονο και μονο για τις....ψυκτρες?Και τα οποια προβληματα ενδεχεται να προκυψουν με cpu-ψυκτρες?
Oχι ΚΑΙ αυτο?
  • ASUS P8Z77-V PRO
  • ASUS P8Z77-V LX
  • ASUS P8Z77-V LE
  • MSI Z77A-GD65
  • MSI Z77A-GD55
  • MSI Z77A-G45
  • Biostar TZ77XE4
Αλλου κοιταω ρε ;
8GB G.Skill TridentX Dual Channel kit, designed especially for the 3rd generation Intel processors and the Z77 platform. DDR3 2400MHz memory kit, PC3-19200, with memory timings of CL10 (10-12-12-31) at 1.65V.
With Intel XPM (Extreme Memory Profile) and equipped with the brand new G.Skill TridentX heatsinks. Features a unique removable top fin reducing height from 54mm to 39mm.
Pre-tested by G.Skill in the motherboards listed below. This is not an exhaustive list and the memory kit may also be suitable for other motherboards not listed here. Please also refer to the G.Skill website for more details.
ASUS MAXIMUS V GENE
ASUS P8Z77-V DELUXE
ASUS P8Z77-V PRO
ASUS P8Z77-V LX
ASUS P8Z77-V LE
ASUS SABERTOOTH Z77
Gigabyte GA-Z77-D3H
MSI Z77A-GD65
MSI Z77A-GD55
MSI Z77A-G45
ASRock Z77 Extreme6
Biostar TZ77XE4
Αλλου κοιταω ρε ;
ASUS MAXIMUS V GENE
ASUS P8Z77-V DELUXE
ASUS P8Z77-V PRO
ASUS P8Z77-V LX
ASUS P8Z77-V LE
ASUS SABERTOOTH Z77
Gigabyte GA-Z77-D3H
MSI Z77A-GD65
MSI Z77A-GD55
MSI Z77A-G45
ASRock Z77 Extreme6
Biostar TZ77XE4
Nυσταξες Γιαννη, νανι :p
Αβυσσος η ψυχη του ανθρωπου. :D
GSkill Ripjaws Z Series 1866 CL 9.0 16GB Memory Kit - Red (4x 4GB, DDR3, Quad Channel, Intel XMP Certified)
Και καλα θα φτανανε στις 14 τίποτα ακόμα όμως :S.Θα γελάω αν περιμένω τις μνήμες για να στήσω το pc :wall:
Γιάννη και προτίμησες τις 8άρες επειδή λένε ότι παίζουν με την gene z και οι άλλες επειδή δεν το λένε και υπήρχε ενδεχόμενο να μην???!!!
Αβυσσος η ψυχη του ανθρωπου ειπαμε! :p
Αυτες 16GB G.Skill DDR3 PC3-14900 RipjawsZ Series for Intel X79 (9-10-9-28) Quad Channel kit 4x4GB λες ;
Συνονοματε και οι samsung και οι gskill εχω δει οτι παιζουν με την gene.
Για εμφανισιακούς λόγους ρεεεεε?????!!!!!
Καληνυχτα. :p
[MENTION=2962]zpaf[/MENTION] Ναι αυτές λέω
btw Malay L212B27B o 3770K μου
Edit:Μνήμες κατέφτασαν.
Asus GTX670 DCII την Παρασκευή μάλλον.Δεν είναι χάρμα το γονίδιο Zpaf?
Και εγω αυτην σκεφτομαι να παρω. Αν θες στειλε ενα pm απο που και ποσο.
Εσεις με τις Geve V ποσταρετε κανα overclock μεχρι να ερθει και η δικια μου.
In terms of features, by default ASUS has a setting to give a ‘MultiCore Enhancement’. In the real world, this means that by default ASUS will overclock your processor to its maximum turbo mode no matter what the CPU load. For comparison with the 3770K, the CPU should be at 39x during single and dual core mode, 38x when using three cores, and 37x under full load. Using MultiCore Enhancement, you get 39x on all cores no matter what the load. Therefore, in our multithreaded benchmark suite, ASUS has a 200 MHz advantage per core over other products that do not enable this feature by default.
AnandTech - Intel Z77 Motherboard Review with Ivy Bridge - ASRock, ASUS, Gigabyte, and MSI
