@GeoF1,VGA.Μπορεις να στειλεις οθονια τις επιλογες σου σε VGA?
Ανοιξε Launcher και video settings(σε single mode).Μετα πηγαινε σε single player-video settings,παρε και εκει μια φωτο.
Επισης μπορεις να κανεις reset τις VGA επιλογες
Έγινε επεξεργασία από Dimitris Pappas
On 2/5/2019 at 7:50 ΜΜ, το μέλος Dimitris Pappas έγραψε:
Αυτα εχω/
Χθες μετα απο restart επαιξε κανονικα
FIA European Hill Climb Championship rFactor2
RACE 3 / MONDAY 13/5/2019 /
RAMPA INTERNACIONAL DA FALPERRA
[IMG]
QUALIFY RACE STARTS AT 20:30 (LOCAL TIME GREECE)
RACE STARTS AT 22:30 (LOCAL TIME GREECE)
QYALIFY STARTS AT 18:30 (GMT)
START OF THE FIRST CAR AT 20:30 (GMT)
WEATHER : LIVE
TYPE OF START: STANDING
NATURALLY PROGRESSING REAL ROAD IN ALL SESSIONS
KEY RULES & REGULATIONS HERE : https://www.hillclimb-virtual-championship.net/rules/
CALENDAR HERE: Group H Special Hillclimb Champiomchip Calendar 2019
Hill Climb Starting procedure
LIVE WEATHER FORECAST
Weather and forecasts in Braga
  • 2 new more cars added (23 cars)
  • 24/7 servers for practice and race with Live Weather and Naturally Progressing Real Road.24/7 .
  • Qualifying session of 120 minutes and 3 laps race ,always with Live Weather and Naturally Progressing Real Road.
  • It is not required to participate in Practice session.
  • It is not required to participate in Qualification. In this case you will start last.
  • Any disconections during race heats means DNF
  • Point system is 50-42-37-32-27-25-22-20-17-15-12-10 for the top 12 finishers.After 12 top finishers all drivers who finish the race gets 3 points for their participation.All DNF gets 1 point.DNS gets 0 point.
  • 2 points bonus are awarded for the fastest qualifier.
  • Drivers who joins the cup during season starts with bonus the last full active driver points.
Server name: GROUP H SPECIAL HILLCLIMB
Pass: koko
Driver List so far:
https://www.hillclimb-virtual-championship.net/drivers/
Driver Standings so far:
https://www.hillclimb-virtual-championship.net/driver-standings/
1 hour ago, GeoF1 said:
@Dimitris Pappas Πως τα βλεπεις αυτα που ποσταρα? Γιατι λεει οτι εχω windows 8?
Εχεις μαματα specs.Μην ανησυχεις τι βλεπει το rf2 σαν λειτουργικο.
Μαλλον το pc δεν εχεις μονο για simracing,ε?
144Hz+Gsync σε 1 οθονη 27αρα...πολυ μικρο καδρο,δεν εχεις καθολου περιφερειακη οραση(δεν βλεπεις apex+αλλους οδηγους).
Με τα specs που εχεις αν θελησεις triples τοτε θα πρεπει να κατεβεις λιγο σε ποιοτητα αν και το Gsync θα σε βοηθησει πολυ να περιοριστει το tearing και αλλα προβληματα.
Με μια οθονη οπως εισαι τωρα οτιδηποτε >80 fps με εννοειτε το Gsync ενεργο και τα settings που εχεις σου δινουν ρευστη εικονα.
Υποψιν το rf2 ειναι πολυ δυσκολο sim σε ομαλη κινηση+αληθοφανη γραφικα αν και πιστευω με το pc σου δεν εχεις κανενα προβλημα να τερματισεις τα settings!
Δευτέρα στον αγώνα θα έχουμε δωροεπιταγές....130 για την ακρίβεια. Ρίξτε μια ματιά στο άρθρο τι περιλαμβάνουν και αν σας ενδιαφέρει σας περιμένουμε στον αγώνα και καλή επιτυχία!!
https://blog.plaisio.gr/whats-hot/to-plaisio-chorigos-toy-15oy-agona-protathlimatos-tis-f1axion-stin-ameriki/
Χωρις να ειμαι γνωστης το Rfactor μου δινει την εντυπωση οτι το Scale των Tracks δεν ειναι σωστο
το assetto corsa και το iRacing εχουνε αψογα Obljects και η κλιμακα τους φαινετε αψογη
Δεν το καταλαβενω γιατι στο RF2 δεν ειναι τοσο πιστικο το αποτελεσμα και δεν αναφερομαι στο Accuracy που δινει το Laser scan μερος της δουλειας αλλα
στο απο κει και περα στο παιχνιδη
κατι παει στραβα αλλα δεν μπορω να το εκφρασω γιατι δεν εχω σχεση με γραφιστικη ,Design και λοιπα.
Μην σκας @Mesfigas1973,μεγαλη κουβεντα για τις πιστες στο ρουφου,φωτισμος,παλεττα,σκιες,ακριβεια,bugs,νομιμα ορια....
Το scaling αντικειμενων εκτος πιστας ειναι τριχα.Βεβαια μπορει να οφειλεται και σε λαθος fov.
Το team δεν εχει πλεον ταλαντουχους αρτιστες και γνωστες(SLN,Hudson Kerr και αλλοι) και το αποτελεσμα ειναι κακες πιστες εκτος απο λιγες εξαιρεσεις(Lilski).
Η τελευταια Zand ψηνεται πολυ καιρο,εχει τα μωβ ιδιοτροπα χρωματα στην ασφαλτο και αλλα προβληματα που σε λιγα λεπτα τα καταλαβαινεις.
Πριν την ανεβασουν κανενας δεν το ειδε απο την ομαδα?Τουλαχιστον ειναι free.
Υπαρχουν και οι χαρντκοραδες που τρεχουν κονβερσιονς απο GPL,gtr2,gp4 και γουσταρουν ρετρο PlayStation φαση.
Η Sebring πρεπει απο δω και περα να ειναι το minimum και οτι βγαινει να ειναι εφαμιλλο η καλυτερο.
Το ρουφου καποτε το κυνηγουσαν τωρα τρεχει να φτασει αλλους.
Το Pbr ειναι πλεον στανταρντ στα παιχιδια και στα CGI.
Το S397 το παει καλα αλλα πολυ αργα.
Η παρακατω φωτο ειναι απο το 2006-7 καπου απο rf1,12 χρονια πισω!
Τα-λε-ντο!Η σημερινη LeMans  στο rf2 eιναι σαν....μπροστα στην παρακατω...
παιζω live for speed και νομιζω οτι ειμαι μεσα στην πιστα
πως ειναι δυνατον να μην το κανουνε το ιδιο με το RF2
ειλικρηνα οι πιστες φαινονται τοσο απολοοικες που νομιζω οτι παιζω pre-alpha
ναι η Sebring πρεπει να ειναι το minimum
βλεπω το RF2 και οι πιστες φενονται Melted
λες και επεσε ο ουρανος και πλακωσε την γη
πριν 6 ώρες, το μέλος Dimitris Pappas έγραψε:
Δεν χρειάζεται να έχεις "ονόματα" για να κάνεις σωστή δουλειά. Αρκεί να βάλεις το χέρι στην τσέπη. Δεν αναφέρομαι στα "τεχνολογικά" προβλήματα που πρέπει να υπερκεράσουν, αλλά στα βασικά που απλά δεν δίνουν καμία μα καμία βάση. Για να κάνεις accurate οπτικά μια πίστα, αφού εξασφαλίζουν δικαιώματα και άρα και cad's δεν είναι πρόβλημα. Λεφτά πρέπει να αποφασίσουν να δώσουν σε ανθρώπους να τους φτιάξουν σωστό content. Αν μπορεί να το κάνει ένας modder με google maps μπορούν να το κάνουν σαφώς καλύτερα. Το θέμα είναι τι επιλέγουν να δώσουν. Που θέτουν αυτοί τον πήχη. Και δυστυχώς κάνουν συνεχώς πασαλείμματα. Τα funboy δεν τους νοιάζει ουσιαστικά, μιας και θα υποστηρίξουν ότι μα..... τους προσφέρει, τα υπόλοιπα να 'χαμε να λέγαμε.
Ένα UI το λιβανίζουν πόσο; Έλεος!
Tools η κοινότητα βρίσκει με το σταγονόμετρο και κακής ποιότητας.
Για το pbr δεν το συζητώ... Ό,τι να ΄ναι. Όταν φτιάχνεις έναν βασικό shader, δουλεύει για παντού. Όχι αυτόν τον μήνα μόνο για τα εξωτερικά μέρη του αυτοκινήτου, σε κανά-δυο μήνες για τα εσωτερικά, μετά για τα kerbs, μετά για τις σημαίες κτλ. Αυτό δηλώνει πως δεν έχεις βάση. Κάνεις δηλαδή (εξακολουθείς) να κάνεις μπαλώματα, πασαλείμματα.
Είναι γελοίο πλέον. Τον τελευταίο χρόνο έχω ασχοληθεί αρκετά με τα τεχνικά του. Δείχνει σε πολλούς τομείς πρόχειρο και μπαλωμένο. Αν δεν το σημαδέψουν... και σύντομα, για μένα δεν έχει μέλλον. Αν δεν ρίξουν λεφτά στη φάση αυτή, θα χάσουν και αυτά που έχουν.
Προσωπικα δεν αγορασα το Reiza pack και το σκεφτομαι πολυ αν θα παρω Nurbur kai Nords laser scan
Πιθανον να μην το παρω
δεν μπορουν να κοφευουν οταν η κοινοτητα τους λεει πως το AI rain bug ειναι βασανηστικο και deal breaker
και να μην κανουνε καποιο fix
χαιρομαι το Competizione πολυ περρισοτερο και αw ειναι Beta με λιγα GT3
και φτιαγμενο για GT3 μονον
Εβαλα να παιξω Zandvoort με Bentley GT3 και ενω τα physics και FFB δεν πιανονται
3:30 ξημερωματα clean sky και αντι να μου διχνει νυχτα ,ειναι λες και παιζω μερα μεσημερη.
και η πιστα ειναι τελευταια εκδοση 1,02
αυτα ειναι
