  • Replies 748
θενκ κιουυυυυυ:flower:
ειπα να κατεβασω την τελευταια εκδοση για τον νεο μου επεξεργαστακο.............we dont need no water let the mother#@$r burn..............
στη συγκεκριμενη περιπτωση we use some water-let the mother@#%r burn
Link to comment
Share on other sites
όσοι θέλετε να τρέξετε το pifast (4.1 ή 4.3) σε realtime αντιγράψτε τα περιεχόμενα των φακέλων στου αντίστοιχους φακέλους του pifast. Με τα shortcut το pifast θα τρέχει σε Realtime ;)
realtl.zip
Link to comment
Μr Endu για ριχτε μια ματια κ εδω...κανανε update.....βασικα ειδα κατι καλο...σχετικα καλο δηλαδη....
εχει κ μερικα αλλα
AMD Athlon 64 Processor Driver for Windows XP, Version (exe) 1.1.0.18 - AMD Athlon 64 Processor Driver for Windows XP allows the system to automatically adjust the CPU speed, voltage and power combination that match the instantaneous user performance need.
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_9706,00.html
Link to comment
RivaTuner 2.0 RC 15.3 New Year Edition
Minor bugfixes:
  • Fixed performance table entry size calculation for BIT-based NVIDIA VGA BIOS images. Now the second performance level's parameters are no longer displayed incorrectly on some GeForce 6800 boards having more than 1 performance level in VGA BIOS (e.g. Gainward 6800GT).
  • Fixed title detection for ATI ATOM VGA BIOS images
  • NVStrap driver's "Graphics processor identification" / "Quadro" mode and "Allow enabling hardware masked units" option no longer conflict when they are activated simultaneously
  • "Cannot reset R/O attribute of destination file" message is no longer displayed when patch script engine creates new destination file instead of overwriting source file.
What's new
  • Added ForceWare 67.xx - 7x.xx driver families support.
  • Updated databases for Detonator and ForceWare driver families. Added databases for ForceWare 66.93, 67.02, 67.03, 70.41, 70.90 and 71.20 drivers.
  • Updated NVStrapAntiprotection and ForceWareAntiprotection patch scripts for ForceWare 66.93, 67.02, 70.41, 70.90 and 71.20 drivers. Take a note that these scripts are fully replaced with NVStrap 1.7 functionality on GeForceFX and newer graphics processors. The scripts are required for GeForce 4 and older display adapters only and subject to be discontinued in the next version.
  • To avoid confusing beginners, which often tend to ignore built-in context help, low-level overclocking tab is now hidden on GeForce FX and newer display adapters.
  • Removed obsolete "Depth buffering" tab in Direct3D tweaks dialog for the ForceWare 65.xx and newer drivers.
  • DirectX7/DirectX8 texture formats options in "Textures" tab / Direct3D tweaks dialog are renamed to DirectX7 and DirectX8+ surface formats.
  • Revised list of available surface formats for new drivers in "Textures" tab / Direct3D tweaks dialog. Added options for controlling new surface formats (e.g. FOURCC ATI2 (3Dc)), removed some obsolete texture formats (e.g. FOURCC NVT0...NVT5).
  • Added full NVIDIA NV41 and NV44 graphics processors support. Now all RivaTuner's features including full low-level diagnostic and low-level pipeline configuration override via the NVStrap driver are available on these graphics processors.
  • Thanks to Andrew Worobiew for testing RivaTuner with GeForce 6200 with TurboCache 16M/32M.
  • Added new PCI-E NV4x PCI DeviceIDs to the database of supported NVIDIA GPUs.
  • Added experimental NV46 and NV47 graphics processors support.
  • Updated NVStrap driver v1.7
  • Added NV40BIOSHwUnitsMaskEliminator patch script, allowing you to remove hardware units mask initialization code from VGA BIOS initialization script. You may use this patch script to finalize pipeline configuration set by the NVStrap driver. The script uses preprocessing plugin feature, introduced in this version, which allows the script to eliminate masking either for all pixel / vertex units or only for units, enabled via the NVStrap driver. Please refer to FAQ for details.
  • Added filename resolving for RivaTuner's files launched via the command line. Now relative file paths (e.g. ".PatchScriptsATIATIOverclockingAntiprotectionRuntimeATIOverclockingAntiprotectionRuntime w2k.rts") can be specified in the command line when launching the file.
  • Added ATI Catalyst driver version detection. Now RivaTuner displays driver family name, the list of installed driver files, file descriptions and versions in the main tab on supported ATI display adapters (for Windows 2000 / XP only).
  • Database of supported ATI / NVIDIA drivers is now user extendable and stored in [DriverFamily_...] and [DriverFiles_...] sections of RivaTuner.cfg file.
  • Added X800SE support. Thanks to Andrew Worobiew for testing RivaTuner with X800SE.
  • Added ATI R430 and R480 graphics processors support. Now all RivaTuner's low-level features including overclocking, thermal monitoring and fan control are available on display adapters based upon these graphics processors. Thanks to Andrew Worobiew for testing RivaTuner with R430 and R480 based display adapters.
  • Updated Catalyst 4.11, 4.12 beta and 4.12 certified SoftR9x00, ATIOverclockingAntiprotection and ATIOverclockingAntiprotectionRuntime patch scripts.
Nero CD-DVD Speed 3.61
  • Create Data Disc: added option to burn Nero image files instead of predefined data
  • Added color selection/themes
  • Disc Quality test
  1. added QuickScan function
  2. improved support for Asus DVD burners
  3. improved support for AOpen DUW1608/ARR
  4. improved support for AOpen DVD1648/AAP
  5. added 12x and 16x speed settings for BenQ DW1620
  6. added elapsed time in summary screen
  • Bitsetting: added DVD+R DL bitsetting for QSI drives
  • Small improvements and bug fixes
RightMark CPU Clock Utility v1.3
  • New (tabbed sheet) user interface design.
  • Added CPU clock, load level and FID/VID monitoring graphs with text file logging feature.
  • Added CPU load level determination on Intel Pentium II/III/M/4 family CPUs.
  • Added throttled CPU clock determination for any forms of CPU clock throttling.
  • Added support for multi-processor (SMP/HT) systems (for both monitoring and FID/VID management features).
  • Added support for "mobile" and "server" (DBS) Enhanced Intel SpeedStep technology on Intel Pentium M and Xeon (Nocona) CPUs.
  • Added CPU-specific power management related settings for AMD K7, AMD K8 and Intel Pentium M/Pentium 4/Xeon family CPUs (for advanced users only!).
  • Added Minimal FID/VID determination and display (where available).
  • Added CPU power management features presence and status display.
  • Improved CPU/OS load measurement with load-averaging feature.
  • Improved FID/VID control logic with CPU load level "noise filtering" (spike removal) feature.
  • Changed default process priority to Realtime priority class.
  • Bugfixed CPU usage determination after resume from Hibernate mode.
  • Bugfixed program settings saving upon termination of Windows session (shutdown/logoff).
SpeedFan 4.19
  • fixed a bug in reading internal properties for some sensors
  • added ULi M1689 SMBus
  • properly identified a different version of SMSC
  • improved IT8702F detection over the
  • trying to fully enable MANUAL PWM mode on SMSC EMC6D103
  • IT8712F support now may need you to enter CONFIG / ADVANCED to set the appropriate PWM MODE (please, read the help file
  • fixed identification of S.M.A.R.T. and AAM for hard
  • added a new section in the help file to explain how to set Advanced Options for IT8712F and other chips (please read it if you no longer can change fan speeds
  • added a new tip if an IT8712F is found
HardwareOC: Half-Life 2 Benchmark v1.3
HardwareOC: Far Cry Benchmark v1.4.1
  • Fixed time error
  • Minor improvements
  • "From System" option in the filters.
Link to comment
Δεν ξέρω αν είναι το κατάλληλο μέρος να ρωτήσω αλλά δεν ήξερα που να το ποστάρω.
Έχω το Everest pro 1.51.195 και δεν βρίσκω πουθενα το Benchmark module
Τόσο στραβός είμαι ?
help please !
:help:
Link to comment
