  • Replies 748
  • 4 weeks later...
OPN64 now supports the following new processors:
  • Athlon 64 (WinChester) 3000+, 3200+, 3500+
  • Athlon 64 (ClawHammer) 4000+
OPN64 now supports the following new features:
  • Support for Max Operating Temperature values 'I', 'K'and 'Y'
download
μερικά links που κάνουν redirect σε post μέσα στο thread μπορεί να μη δουλεύουν, θα διορθωθούν σε επόμενη ανανέωση
Link to comment
Share on other sites
ATITool 0.0.23 beta 9
  • Added option to use "old scanning method"
  • Fixed issues in "Startup" settings
  • Added Catalyst AI support for 4.9 drivers
  • Added detection/overclocking/mem timings support for X800 SE AGP
  • Fixed crash issue on non-ATI cards
Sandra Lite 2005 10.37
  • New Connect Wizard: Allows connection to remote PCs, servers, Pocket PCs, Smart Phones and databases
  • New Environment Monitor Wizard: Allows monitoring of a computers's environment (temperatures, fan speeds, voltages, CPU power and cooling system thermal resistance)
  • New Key Applications List: Lists the key applications registered on the computer (Address Book, Anti-Virus, Calendar/Organiser, E-mail client, Firewall, Instant Messaging, Internet Call, Java Virtual Machine, Media Player, News Reader, Web Browser)
  • New On-Disk Programs & Libraries List: Complete list of all programs and libraries on the computer, whether registered or not
  • New Installed Web Packages List: Shows ActiveX components and Java classes installed
  • New Start Menu Applications List: Compiles list of all applications registered on the computer's Start Menu
  • Enhanced Winsock & Security Information: Provides information on installed software firewalls and network adapters
  • Single multi-platform installer: Contains 3 native ports for each Windows platform (Win32 x86, Win64 x64, Win64 IA64) as well as native remote analysis service for Windows CE platform (ARM Pocket PC, ARM Smart Phone, x86 Standard) all-in-one
  • Multi-Core Support: As well as SMP (multi-processor) and SMT (multi-threading/Hyper-Threading) support we have added multi-core support for future AMD and Intel CPUs
  • Native Unicode Product: The client, service, libraries and device driver are all native Windows Unicode products designed for Windows 2000, XP and 2003
  • Signed Product & Installer: The client, service, libraries, device driver and installer are all signed with our digital certificate for your protection
Link to comment
endu.......καμια βοηθεια θες?????
Fixes:
4.18 - added manual multipliers (from 1 to 20) and divisors (from 1 to 20) for all fans (use CONFIG / ADVANCED)
- added manual reverse for PWM logic in CONFIG / ADVANCED
- added full support for NE1618
- SEND REPORT no longer accesses some NE1619 registers
- added preliminary russian translation (thanks to Pavel Gourkov)
- SiS741 SMBus is no longer identified as SiS5595
- added manual offsets for all temperatures (use CONFIG / ADVANCED)
- added preliminary support LPC47M292
- started using controls with a newer look
- added preliminary Spanish and Galician translations
λινκ.........
http://www.almico.com/speedfan418.exe
:T:
Link to comment
σου χω κι αλλα...........
Changes:
Disc Quality Test: Added support for Asus DVD recorders
Fixed incompatibility with PlayStation DVDs
Small improvements and bug fixes
Added bitsetting function
Disc Quality Test
Added support for Plextor PX-116A3
Added 1x speed setting for AOpen DVD1648/AAP
Erase function
Full format is possible
DVD+RW with DVD-ROM book type can be erased now
link
http://cdspeed2000.com/files/NeroCDSpeed_355.zip
:T:
Link to comment
θα σου λεγα τωρα καμια κουβεντα........απλα μου κατσε να ψαξω τιποτα μιας και εκανα φουλ την dsl.......μην ξεχνας οτι εχω ακομα το 512αρι σου....χοχοοχχοχο:hehe:
α...και αλλαξε επιτελους αυτην την αλανιαρα στο αβαταρ σου....:whip:
Link to comment
Μη μαλώνετε θέλω να είστε αγαπημένοι :T: Ωραίος Γιώργο, καιρός να ανανεώσω και γω την λίστα στην αρχική.
ATI Tray Tools 1.0.1.410
  • Improved TV/Display support
  • Added support for Radeon X850 Series
  • Added Support for Enable/Disable Extended Desktop
  • Added Screenshots system
  • Added new Apply 3D setting mode
  • Audio options moved to "General Options" dialog box
  • Fixed some bugs in installation procedure
  • Fixed bug with Hot Key editor
S&M 1.3.0 (Build 160) Alpha
RightMark Memory Analyzer v3.43
  • Fixes to ResultsBrowser component (CSV files export)
  • Fixes to DMI info reading on systems with DMI residing outside system BIOS space
  • Min/Max CPU multipliers determination on Pentium 4 and Athlon 64 family CPUs
    Celeron D support
Link to comment
PingPlotter is version 2.51.1 (released June 16th, 2004)
Eνα πολύ καλό PING PLOTTER / TRACER για την ADSL σας......
Μπορείτε να το κατευάσετε από ΕΔΩ
Αυτά είναι τα δικά μου PING.... ;)
Kαι μερικά features ....
Easy to use! PingPlotter's basic mode means you just type in the address you want information about and hit "Trace". It starts tracing and shows you a graph. Someone with no network experience can see where their packets are being dropped and contact their ISP with this information.
Graphs the response time through the route of the packet from source to destination. This really highlights problem hops and lets you concentrate on trouble areas.
Uses multiple threads to increase performance and accuracy. This means that PingPlotter doesn't wait for hop 1 to respond before sending out a request to hop 2. A complete 1 sample trace can be done in about 5-10% of the time it takes to do a trace with the Windows "TRACERT" command (usually less than 1 second for PingPlotter vs 15-45 seconds for TraceRT).
Graphs any host over time - lets you scroll back and forth over time, and zoom in on any specific time to find out where problems occur. You can even graph multiple hops at the same time.
PingPlotter's graph can be resized, rescaled, zoomed, dragged and manipulated to give you exactly the information you need to find a problem. Helps you identify whether a connectivity problem is your ISP or network, the host you're connecting to or somewhere on the internet between you and the remote host. Ping Plotter will even help you identify which network (Digex, Cable & Wireless, Alternet, MCI, Sprint, etc.) is the source of your problem down to the specific node.
Creates nice images (via clipboard copy, or saving as .BMP or .PNG files) that can be sent via e-mail. Face it, text dumps of a bunch of numbers aren't always the most compelling evidence. Put a picture on that data that shows where the problem lies and let your network provider argue with you then!
Schedule automatic saving of images (in BMP or PNG format), or saving of the underlying raw data. Use this to collect data over a long period automatically.
Keep track of route changes. No other product tracks route changes like Ping Plotter - giving you the ability to see what route your data was taking at any time in your tracing session.
Can do traceroute using either Windows-standard ICMP echo requests, or Unix-standard UDP requests. Some ISPs block one, and not the other - this gives you more opportunities to be able to collect performance data - even if your ISP doesn't want you to.
Exports any portion of your collected data to a text file for analysis by other software packages (e.g. Microsoft Excel). If Ping Plotter doesn't graph it the way you want it, use your favorite graphing software and do it yourself!
Built for long-term monitoring. Ping Plotter works GREAT for overnight or even multiple-day monitoring projects. Set your interval and let it run. Check back later and review the history to find out trends and problem times. Does the speed degrade at 9PM and improve at 1AM? Ping Plotter will make that VERY clear and give you all the data to present to your ISP.
Will save your accumulated data for a host to a file and then allow you to reload and continue. Some users have reported running Ping Plotter continously for months, and we've been running it here at Nessoft continuously for years. We have well over 20 million samples collected and automatically saved for the last 4+ years of Nessoft.com site performance!
You can save and load sample sets - and then resume the trace. This way you can have multiple sessions of data in the same graph.
High performance, low overhead. There is no traceroute package available that returns results faster. Ping Plotter is FAST and it uses very little CPU to do its job. That means you can run it continuously without interfering with your other tasks.
Alerts! Alerts will allow you to set parameters where you want to be notified of the condition. If the conditions fire an alert, you can log that data to a text file, play a wave file, launch another program of your choice, change your tray icon, or send yourself e-mail with the pertinent information included.
Built-in Whois. You can query for a server by name, or the ARIN servers by IP address (to see who owns and runs a particular IP address).
Link to comment
  • Fixed startup.bat for Partition Resizer and TestDisk. Thanks to Jan Stocker for the information.Fixed the mixup of QNX modem and network bootdisks in others.scn. Thanks to Darren for the information.
  • Compressed wipecmos.com with Crunch to avoid false alarm from NAV. Thanks to Yuval Melamed for the suggestion.
  • Updated F-Prot to V3.15b. Updated F-Prot virus definitions to 30 Nov 2004. Thanks to various people for informing me about this.
  • Updated McAfee virus definitions to 1 Dev 2004.
  • Updated MemTest86+ to V1.40. Thanks to ckit for the update.
  • Updated TestDisk to V5.5. Thanks to Christophe Grenier for the update.
  • Removed redundant TestDisk image from "images" subdirectory.
  • Updated MemTest86 to V3.2. Thanks to ckit for the update.
  • Updated IBM Drive Fitness Test to V4.00. Thanks to ckit for the update.
  • Updated GAG to V4.5d. Thanks to SebastienG for the update.
  • Updated Partition Saving to V2.91. Thanks to SebastienG for the update.
  • Added MSRRC (Bart's Network Disk on FreeDOS) V3.18. Thanks to Erwin Veermans for the contribution.
  • Updated NwDsk to V3.18. Thanks to Erwin Veermans for the update.
  • Updated FreeDOS boot image. Thanks to Erwin Veermans for the update.
  • Updated memdisk to V2.11. Thanks to Erwin Veermans for the suggestion.
  • Updated PCISniffer to V1.3. Thanks to SebastienG for the update.
  • Updated Intel Processor Frequency ID Utility to V7.2.20041115. Thanks to SebastienG for the update.
  • Updated CMOSPWD to V4.4.
download
Link to comment
