kallileo Σεπτέμβριος 12, 2004 #101 Κοινοποίηση Σεπτέμβριος 12, 2004 1.0.1.371Reverted 3D detection code for OpenGL application to old one. Because build 370 of ATI Tray Tools and FRAPS use same procedures to detect OpenGL activity, there are known bugs when 3d applications doesn't start. I have decided to revert my code to old detection procedure, which has no conflict with fraps.1.0.1.370Updated Plug-Ins API. Added Run Time type plug-ins. These plugins will be executed at ATT start up.Added PCI Register Set plug-in. Using this plugin, you can create list of PCI registers, which will be programmed at start-up. Also these registers will be restored after suspend/hibernate mode. Useful for setting BUS Disconnect on/off on motherboards without such option in bios.Example:For motherboards using nVidia nForce 2 Ultra 400 chipsets you can enable "BUS Disconnect" and "Halt Monitor detect" using these values.bus = 0device = 0function = 0register = 6Fvalue = 9FAdded CPU Load metter plugin with full source as example of "How to create Run time plugins and show information in system tray".Updated Radeon Info plug-in. Updated Games Profiles. Added option to close ATT after game end. But be careful and don't ask me if you got an error! If you set as game executable an loader, not the game itself, and this loader will be terminated after game start, ATT will be terminated too! Just remember. ATI Tray Tools will monitor .exe file provided as Game Executable!Added option to load color profile at start up. Fixed bug with TemporalAA in OpenGL configuration form. Added OEM settings. (If you want to include ATT in your software/drivers package, please contact me first! I will provide more information)ATI Tray Tools 1.0.1.371 S.M.A.R.T. Viewer Link to comment Share on other sites More sharing options...
kallileo Σεπτέμβριος 12, 2004 #102 Κοινοποίηση Σεπτέμβριος 12, 2004 it's now free for all, no limited shareware version anymorereduced cpu + driver overhead through redundant render state filteringGPU performance optimized resource allocation support for shader model 2_b and 3_0nearly all shaders undergone changes and fixes testing of >2_0 shadersdynamic pixel shader flow control testing floating point texture filtering performance testingmultiple render target performance testingmultiple shader testmean square error (MSE) calculation in the image quality test - hardware rasterizer vs. Microsoft reference rasterizerdownload Link to comment Share on other sites More sharing options...
enduracell Σεπτέμβριος 13, 2004 Author #103 Κοινοποίηση Σεπτέμβριος 13, 2004 2.3.1Fixed crash in 2.3.0 when Save Detailed Benchmark Statistics enabledFixed incorrect colors recorded from games running in 16-bit color2.3.0Many changes for optimum video recording under WinXP SP2New 256 color capture engine (perfect quality, smaller filesize)Added JPG and PNG screen capture support (registered users) Fixed rare codec decoding bugdownload Link to comment Share on other sites More sharing options...
aliendna51 Σεπτέμβριος 13, 2004 #104 Κοινοποίηση Σεπτέμβριος 13, 2004 Να γίνει Sticky! Link to comment Share on other sites More sharing options...
enduracell Σεπτέμβριος 13, 2004 Author #105 Κοινοποίηση Σεπτέμβριος 13, 2004 New ResultsBrowser featureNew supported chipsets: Intel E7205, E7500, E7501, E7505, E7520, E7525, AMD8000, VIA K8T800, K8T800Pro (AMD64 integrated memory controller), nVidia nForce2 SMBus controllerDMI info (BIOS, Motherboard and System Vendor, Model and Revision)New CPU Database EntriesdownloadΑρχική απάντηση από aliendna51 Να γίνει Sticky! είναι είδη sticky.:flower: Link to comment Share on other sites More sharing options...
aliendna51 Σεπτέμβριος 13, 2004 #106 Κοινοποίηση Σεπτέμβριος 13, 2004 είναι είδη sticky.:flower: :whistling Link to comment Share on other sites More sharing options...
fantacid Σεπτέμβριος 13, 2004 #107 Κοινοποίηση Σεπτέμβριος 13, 2004 Hiren's BootCD 6.0 info downloadΠολυ χρησιμο σε δυσκολες καταστασεις !!!!κ το νεο project του Alex Van Kaam samurize Link to comment Share on other sites More sharing options...
enduracell Σεπτέμβριος 13, 2004 Author #108 Κοινοποίηση Σεπτέμβριος 13, 2004 Το Ηιren's BootCD περιέχει λογισμικό warez (ghost, partition magic) και το link απομακρύνθηκε.Το samurize τι είναι δε το έχω υπόψιν μου, σαν το MBM είναι? Link to comment Share on other sites More sharing options...
fantacid Σεπτέμβριος 13, 2004 #109 Κοινοποίηση Σεπτέμβριος 13, 2004 Oops sorry για το hirens....παντως εχετε το υπ'οψιν σας!!Ναι κατι σαν το ΜΒΜ,με περισσοτερο monitoring κ skinable. Link to comment Share on other sites More sharing options...
enduracell Σεπτέμβριος 13, 2004 Author #110 Κοινοποίηση Σεπτέμβριος 13, 2004 Nαι το checkάρα στα screenshots φαίνεται πολύ πρώτο το progι αλλά είναι περισσότερο κάτι σα το desktop sidebar... δε ξέρω που να το βάλω? Link to comment Share on other sites More sharing options...
enduracell Σεπτέμβριος 13, 2004 Author #111 Κοινοποίηση Σεπτέμβριος 13, 2004 New Features (1.1.1b)slide out menu and controls to preserve desktop space.fully functional S.M.A.R.T. HDD Health checker.added a completely new field to the PSU calc, user defined wattages (green) along with a button to reset them back to the application defaults.temperature conversion tool.VRAM Ns conversion tool (now in its own window).included Intel P13 SYS clock / FSB architecture in the FSB calculations.included dual fields for the P4 IPS calculations, one for Hyperthreading, and the other for nonhyperthreading.included the system clock in the FSB ratios to allow a better idea of the contrasts.probably something I missed...Bugfixesimplemented a cheap hack to keep a divide by zero error away from FSB Ratios and the Temperature Calc.fixed the main windowsborder style to a fixed position.toned down the default wattage multiplyers to closer represent the average wattages of system components.cleaned up the behavior of certain command buttonsfixed tab order, yer welcome...Known Bugsstrange backspace behavior when editing text boxesstill possible to completely clear text box contents and apply a calculation, resulting in a critical error. (looking for help on this noobish problem) download Link to comment Share on other sites More sharing options...
kallileo Σεπτέμβριος 17, 2004 #112 Κοινοποίηση Σεπτέμβριος 17, 2004 ASTRA32 - Advanced System Information ToolΜετα το AIDA το ASTRA......πολυ δυνατο.detection of DVD read/write speeddetection of DVD-RW/DVD+R/DVD+RW read-write featuresdetection of AC'97 sound codec name and its featuresdetection of Intel Celeron M (Dothan), Intel Xeon (Nocona), AMD Sempron (Thoroughbred) and AMD Sempron (Paris) processorsInsyde BIOS for MiTAC and Phoenix BIOS for Samsung supportIntel Extended Memory 64 TechnologySend Task Priority Messages and AMD Fast Save and Restore detectionminor improvements, bugfixes, etc.download Link to comment Share on other sites More sharing options...
enduracell Σεπτέμβριος 18, 2004 Author #113 Κοινοποίηση Σεπτέμβριος 18, 2004 NiBiTor v1.6Changed name from 'OmniExtremeEdit FX' to 'NiBiTor' (nVidia BIOS Editor) name is much shorter and makes more sense...Fixed BFG6800U 2D SpeedsFixed 5900XT Timing A5900 Class: Memory Speed will be set the same in all modes, to avoid possible conflicts with Beta ForceWare DriversAdded Option to edit memory speed table entries for problematic 5700 BIOSesFixed new versions linkNero CD-DVD Speed 3.30Added color selection/themes.Added support for Asus DVD-E616P2, CRW-5232AS and CRW-5232BAdded speed settings for AOpen DVD1648/AAP and LiteOn SOHD-167TImproved support for QSI/NU Tech and AOpen drivesMany small improvements and bug fixesSpeedfan 4.16added nVidia nForce2 clock controlverified support for nVidia nForce3 150 SMBusidentified nVidia GeForce FX Go 5200added detection for LPC47m182added detection for LPC47n350 new versionadded detection for LPC47m976added detection for LPC47m260added support for W83627THF at non standard addressadded special properties for ADM1031fixed a mistake with ADM1031 propertiesadded detection for generic PC87591added a link to SpeedFan's website on the INFO tab Link to comment Share on other sites More sharing options...
kallileo Σεπτέμβριος 18, 2004 #114 Κοινοποίηση Σεπτέμβριος 18, 2004 Improved:Small code changesAdded:S3 Savage cleaning file betaCab Cleaner Fixed:Bug with temp directoryWhen cleaning drop down box disableddownload Link to comment Share on other sites More sharing options...
RootX Σεπτέμβριος 19, 2004 #115 Κοινοποίηση Σεπτέμβριος 19, 2004 Με ωραίο μπλεδάκι και αναγνώριση του spd των μνημών link AMD Sempron support New SPD tab PCI-Express graphic interface support Link to comment Share on other sites More sharing options...
blade_pan Σεπτέμβριος 19, 2004 #116 Κοινοποίηση Σεπτέμβριος 19, 2004 Τα timings με τα SPD timings τι διαφορα εχουν στο cpu-z...γιατι εμενα στη μια καρτελα λεει διαφορετικα απο την αλλη!? Link to comment Share on other sites More sharing options...
RootX Σεπτέμβριος 19, 2004 #117 Κοινοποίηση Σεπτέμβριος 19, 2004 Προφανώς διότι το spd στις μνήμες σου δεν είναι το ίδιο με αυτά που έχεις θέσει χειροκίνητα....Πχ, καμία bh μνήμη δεν έχει spd, 2-2-2-5. Link to comment Share on other sites More sharing options...
blade_pan Σεπτέμβριος 19, 2004 #118 Κοινοποίηση Σεπτέμβριος 19, 2004 Χμμ...οντως bh-5 εχω και μου λεει 2-3-3-7, ενω το εχω 2-2-2-11 !Αυτο ειναι καλο,δηλαδη μου λεει πως πρεπει να τα εχω κανονικα?:OT: Το sig μου πως μπορω και γω να το κανω ετσι? Link to comment Share on other sites More sharing options...
RootX Σεπτέμβριος 19, 2004 #119 Κοινοποίηση Σεπτέμβριος 19, 2004 Το spd, μεταξύ άλλων, περιέχει και τα προκαθορισμένα από το εργοστάσιο timings, ώστε αν επιλέξεις από το bios "by spd" στις ρυθμίσεις της μνήμης, να καταλάβει τι timings να βάλει. Σε λάθος topic κάνουμε αυτή τη συζήτηση, για επιπλέον απορίες, σε άλλο thread στην σωστή κατηγορία Link to comment Share on other sites More sharing options...
blade_pan Σεπτέμβριος 19, 2004 #120 Κοινοποίηση Σεπτέμβριος 19, 2004 οκ,thanks.... Link to comment Share on other sites More sharing options...
