dmarccos Ιανουάριος 9, 2012 #704 Ιανουάριος 9, 2012 Open Hardware Monitor v0.4.0b Reveal hidden contents Added an option to show the sensor-plot in a separate window or on the right of the tree-view.Added support for saving and restoring the sensor history as shown in the plot for the last 24h.Added a context menu to the plot which allows the user to configure the time window for plotting.Added code to save and restore the plot sensor selection.Added support for AMD family 12h (Llano) and 15h (Bulldozer) CPUs.Added support for package level temperature sensors on new Intel Sandy Bridge CPUs.Added support for Intel CPU power sensors (package and cores).Improved the CPU load sensors. The values displayed for the load per core and the total load should now be more accurate.Rewritten the SMART HDD and SSD monitoring code based on a patch by Roland Reinl. The report now contains a list of all SMART attributes with the labels as identified by the Open Hardware Monitor.Added support for SMART total host writes and total host reads sensors on SSDs.Further restricted the identification for Indilinx SSDs to prevent Maxtor HDDs to be identified as Indilinx SSD.Added the hard drive firmware version to the report.Added support for the Fintek F71889AD super I/O chip.Added support for the ITE IT8772E super I/O chip.Added support for fan control on the NCT677X super I/O chips.Added fan control for Nvidia GPUs based on a patch by Christian Vallières.Extended the identification list of mainboard manufacturers.Added mainboard specific configurations for the Gigabyte Z68X-UD7-B3, ASUS P8P67, ASUS P8P67 EVO, ASUS P8P67 PRO and Shuttle SH67Hx mainboards.Added a third decimal place for voltages to the displays.Optimized the memory allocation behavior of the GUI.
dmarccos Ιανουάριος 16, 2012 #705 Ιανουάριος 16, 2012 Real Temp v3.70-Support for Sandy Bridge CPUs.-VID based power consumption estimates for the newer CPUs.-Improved log file formatting.-Added a single system tray icon that reports the maximum core temperature.-RealTemp GT updated for the 6 core Sandy Bridge E CPUs.-i7 Turbo GT 1.30 multiplier monitoring tool.
dmarccos Φεβρουάριος 6, 2012 #711 Φεβρουάριος 6, 2012 HWMonitor v1.19changelog-Intel Core i7-3960X, 3930K and 3820 (SandyBridge-E) and X79 chipset.-Intel IvyBridge processors-AMD Opteron Interlagos and Valencia (Bulldozer)-Improved voltages report for lot of new mainboardsDownloadsSetup (32-64bit), zip 32bit, zip 64bit
dmarccos Φεβρουάριος 13, 2012 #714 Φεβρουάριος 13, 2012 Gpu-Z v0.5.9Changelog-Added support for AMD Radeon HD 7750 and HD 7770 -Added voltage monitoring for HD 7950 and HD 7970-Fixed memory size readings for ATI cards with large VRAM-Improved formula for NVIDIA ASIC Quality reading-Added explanation text to ASIC quality window-Fixed bug that caused updater to show up even though no update available, lagging GPU-Z.-When multi-GPU setup detected, PCIe load test will recommend full screen-Added board ID to BIOS version readout-Added option to show sensor reading in GPU-Z title (click the arrow next to the sensor name)-Refresh sensors in background now defaults to enabled-Fixed release date for HD 7950-Added PCI vendor Packard Bell-Fix for ATI hardware access breaking on Catalyst 12.1-Added fan RPM monitoring support on some ATI cards-Added GF108 based GT 520, GTX 555 (non-mobile), GeForce 305M, 610M
hayabusa Φεβρουάριος 29, 2012 #715 Φεβρουάριος 29, 2012 HWMonitor Pro 1.13HWMonitor Pro (64-bit) 1.13
dmarccos Μάρτιος 19, 2012 #719 Μάρτιος 19, 2012 GPU-Z v0.6.0Changelog-Added optional GPU-Z installer which launches when GPU-Z is started for the first time, or can be started manually via the GPU-Z system menu-Added support for AMD Radeon HD 7870, HD 7850, HD 7670M, FireStream 9370, FirePro V3900-Added support for NVIDIA GeForce GTX 680, GT 640M, GTX 560 SE, GT 550M, GeForce 510, NVS 2100M-Fixed clocks not showing correctly on some systems with Catalyst 12.2-Fixed board id reading on pre-Fermi cards-Fixed OpenCL detection for ATI Fusion (Sumo & Ontario)-Fixed GPU-Z window getting cut off at certain DPI settings
hayabusa Μάρτιος 21, 2012 #720 Μάρτιος 21, 2012 HWiNFO32 Portable 3.94HWiNFO64 Portable 3.94HWiNFO32 3.94
