hayabusa Αύγουστος 19, 2011 #681 Αύγουστος 19, 2011 AIDA64 v1.85 - OpenGL 4.2 support - Improved support for Socket FM1 motherboards - Temperature, fan speed, voltage correction - GPU details for Nvidia's GeForce 510 and GeForce GTX 580M graphics cards.
hayabusa Αύγουστος 19, 2011 #682 Αύγουστος 19, 2011 AIDA64 v1.85 - OpenGL 4.2 support - Improved support for Socket FM1 motherboards - Temperature, fan speed, voltage correction - GPU details for Nvidia's GeForce 510 and GeForce GTX 580M graphics cards.
hayabusa Αύγουστος 25, 2011 #683 Αύγουστος 25, 2011 GPU Caps Viewer 1.14.0 - OpenGL 4.2 support - New: added a new module in the OpenGL panel called glMAXXX to list all OpenGL caps (max values). - New: added all OpenGL caps (max values) in the report. - New: added txt file format for report export. - Bugfix: in OpenCL extensions list: removed the empty extension.
TifoziF1 Αύγουστος 26, 2011 #684 Αύγουστος 26, 2011 ^^ [MENTION=3673]hayabusa[/MENTION] λαθος link έχεις βάλει
dmarccos Σεπτέμβριος 1, 2011 #686 Σεπτέμβριος 1, 2011 GPU-Z v0.5.5Changelog-Added PowerColor hardware giveaway-On multi-GPU systems, GPU-Z will remember the selected card from the selection dropdown-Added full support for AMD A-Series Fusion processors-Added detection for ASUS MARS II-Fixed shader count detection for Blackcomb (mobile AMD Cayman)-Improved BIOS version reading on NVIDIA-Added support for NVIDIA GeForce GT 560 Ti OEM, GT 545, GT 530, GeForce GTX 580M, GT 555M, GeForce 520MX, GT 520M, 410M, 305M, Quadro 5000, Quadro 4000M, Quadro 400-Added support for AMD HD 6290, Radeon E6760 & E4690, FirePro V8800, FirePro V3700, FirePro 2460 (FireMV)
hayabusa Σεπτέμβριος 3, 2011 #687 Σεπτέμβριος 3, 2011 EVGA Precision 2.0.4- Updated SDK seriously improves EVGA Precision extendibility: Added shared memory interface allowing any third party application to access EVGA Precision hardware monitoring statistics. The interface is intended for future EVGA software products integration with EVGA Precision, however, the shared memory layout is publicly open so third party developers can use it to access EVGA Precision hardware monitoring statistics from their own applications. Added shared memory interface allowing any third party application to change graphics card clocks and fan speeds via EVGA Precision. The interface allows developing a lot of useful external applications, for example smartphone overclocking client applications connected to the PC server and remotely controlling the hardware via EVGA Precision and so on. Added sample code, demonstrating On-Screen Display usage from any third party application. The sample is displaying CPU usage in On-Screen Display and provides third party developers helper object for RivaTuner-styled grouped OSD text formatting - EVGA On-Screen Display server has been upgraded to version 4.2.2. New version gives you the following improvements: Tuned vertex buffer usage strategy improves performance in Direct3D8 and Direct3D9 applications in raster 3D On-Screen Display rendering mode Fixed vertex buffer corruption bug, causing On-Screen Display to flicker randomly in Direct3D8 and Direct3D9 applications when raster 3D On-Screen Display rendering mode is enabled Now raster font uses managed texture instead of dynamic one to bypass broken high resolution dynamic texture pitch reporting on GTX 200 series graphics cards under NVIDIA 275.27 beta drivers Raster font texture size is no longer fixed. Now the server is dynamically selecting minimum possible texture size to fit selected font into it The skins have been changed slightly to provide more convenient raster font customization. Now raster font customization window can be open by clicking "Raster 3D" button. Holding "Ctrl" button while clicking "Raster 3D" button allows you to select pre-rendered font from bitmap file and holding "Shift" button while clicking "Raster 3D" button allows you to pre-render and save currently selected font to bitmap file Fixed bug causing multiple used On-Screen Display slots to overwrite each other instead of merging the slots correctly Added screencapture support for Direct3D10 and Direct3D11 applications using framebuffers with 10-bit RGB components (e.g. Dirt 3) Added screencapture support for Direct3D10 and Direct3D11 applications using BGR framebuffers (e.g. F.3.A.R.) Improved tabbed text formatting Updated profiles list - Now sound alarm usage is reflected in "Properties" column of active hardware monitoring graphs list in "Monitoring" tab - Minimum clock limits have been reduced from 75% to 50% - Changed current value and time labels rendering Z-order in hardware monitoring graphs renderer - Improved active monitoring graphs list control in “Monitoring” tab reduces list flickering when hovering mouse cursor over it - ReadMe file is now provided in RTF format instead of plain text format - Wrong tooltips are no longer displayed when hovering mouse cursor over some GUI elements in advanced properties window - Skin format reference documentation has been updated to v1.4 with some minor typo fixes
hayabusa Σεπτέμβριος 6, 2011 #688 Σεπτέμβριος 6, 2011 HWiNFO32 3.86 - Added nVidia GeForce GTX 460 v2, GeForce GT 520MX, GeForce GTX 580M and GTX 570M. - Enhanced sensor monitoring on ASRock 880G Pro3. - Enhanced sensor monitoring on Gigabyte G1.Sniper 2. - Added support of new Panther Point SKUs. - Enhanced sensor monitoring on Asus M5A97 series. - Added possibility to change the sensor scan interval. - Added EC-ACPI Synchonization (HWiNFO32/64 Embedded Controller requests are synchronized with ACPI). - Improved identification of Intel 6-series chipset B2/B3 stepping in case the Compatibility Revision ID feature is enabled. - Improved branding of AMD Family 15h (Bulldozer). - Fixed GPU Shader Count report for Blackcomb. - Enhanced sensor monitoring on Asus F1A55.
hayabusa Οκτώβριος 11, 2011 #690 Οκτώβριος 11, 2011 HWiNFO32 & HWiNFO64 3.88 - Added reporting of total CPU usage. - Enhanced sensor monitoring on MSI MS-7676 (Z68MA-ED5). - Added a new method for measuring CPU clock for Nehalem and later CPUs. - Fixed a possible crash on Sandy Bridge-E/EN/EP. - Fixed Sandy Bridge-E/EN/EP SPD read support. - Enhanced sensor monitoring on Intel DZ68 series. - Enhanced support of VIA Nano and later, added reporting of core temperatures. - Added reporting of current CPU core clock in sensors. - Added nVidia GeForce 610M and GeForce GT 630M. - Added possibility to include multiple items per one RivaTuner OSD line. - Enhanced sensor monitoring on ASRock 990FX.
dmarccos Οκτώβριος 26, 2011 #693 Οκτώβριος 26, 2011 Aida64 v2.00.1700 stableNew features & improvementsAutomatic Online UpdateSupport for LGA2011 Intel “Sandy Bridge-E” processorsPreliminary support for AMD “Krishna” and “Wichita” APUsPreliminary support for Intel Atom “Cedarview” processorsPreliminary support for Intel “Ivy Bridge” and Intel 7-Series chipsetsEnhanced support for Western Digital hard disk drivesRevamped ACPI table enumeration and decodingSupport for VMware Workstation v8GPU details for AMD Radeon HD 6625M and nVIDIA GeForce GTX 570MFull changelog
hayabusa Νοέμβριος 3, 2011 #694 Νοέμβριος 3, 2011 SpeedFan 4.45 - added full support for ITE IT8772F - added support for Fintek F71889A - added full support for SMSC EMC2103-1 and SMSC EMC2103-2 - added support for Fintek F71869AD - added support for Fintek F71862 at unusual addresses - preliminary support for SMSC SCH5317 - fixed Nuvoton W83627DHG-P PWM MODE advanced settings - fixed ASUS ATK0110 readings on several motherboards - fixed ATK0110 support on some Asus motherboards - enabled SMBus on Intel ICH9M-E, if needed - added full AMD Hudson-2 SMBus support - TACPISonySensor support is now probed on all SONYs - fixed multiple glitches and bug related to Advanced Fan Control UI - in Advanced Fan Control dialog, control points can be fine tuned (+1,-1,+10,-10) using the right mouse button - SMART Fitness synthetic value now is more stringent with some specific issues, reporting 0% in some cases that require immediate attention
hayabusa Νοέμβριος 8, 2011 #696 Νοέμβριος 8, 2011 HWiNFO32 3.90 - Improved sensor monitoring on multi-threaded systems. - Enhanced support of systems with multiple CPU groups. - Enhanced support of Nehalem-EX. - Added preliminary support of Ivy Bridge-EP/EX. - Extended new clock measurement method to AMD 10h and 15h families. - Enhanced NVAPI GPU fan speed monitoring. - Minor bugfixes and improvements. - Improved reporting of GPU Memory clock on later AMD GPUs (R700 and above). - Raised sensor limits. - Added reporting of system memory usage in sensors.
dmarccos Νοέμβριος 23, 2011 #698 Νοέμβριος 23, 2011 CPU-z 1.59changelog- AMD Opteron Interlagos and Valencia (Bulldozer).- AMD SR56x0 I/O bridge and SP5100 southbridge (Maranello).- Intel Core i7-3960X, 3930K and 3820 (SandyBridge-E).- Intel X79 chipset (Jaketown).- VIA Nano 1000/2000/3000, Eden X2, Nano X2/X3, QuadCore.- Support for Windows 8.
dmarccos Νοέμβριος 25, 2011 #700 Νοέμβριος 25, 2011 GPU-Z v0.5.6ChangelogRemoved PowerColor hardware giveawayAdded support for ATI Radeon HD 6320, ATI FirePro V9800, AMD FirePro V4900Added support for GeForce GTX 560 Ti 448 cores, GeForce GTX 460 v2, NVIDIA Quadro NVS 420, NVIDIA Quadro NVS 450, NVIDIA Quadro FX 380 LPFix for incorrect shader reading on BlackcombAdded basic detection for NVIDIA Kepler GK107
