Θα προσπαθήσουμε να συμμαζέψουμε την βάση από τις καλημέρες και σήμερα το απόγευμα θα προχωρήσουμε σε αναβάθμιση. . . ×
Fraps 3.2.4
- Fixed counter appearing on Windows Live 2011 apps
- Fixed inverted colors in video captured from some DX10 games
- Fixed DWM capture jumping between multiple monitors on Windows 7
- Fixed flickering counter in some OpenGL applications
- Fixed mouse offset in 3D browser apps
- Fixed FRAPS.EXE not appearing signed on some Windows 7 installations
- Fixed systray icon not turning pink in loop recording mode.
- Fixed startup crash on 24-core CPU systems
- Other minor bug/stability fixes
Link to comment
Share on other sites
  • Replies 748
FluidMark 1.3.0
- New: scoring system change. Now the global score is the sum of PhysX score and GraphX (3D rendering) score. The global score is more appropriate to reflect the gain brought by a dedicated PhysX card.
- New: added a new option to increase the graphics workload ([More graphics load] checkbox).
- Change: online submission improved.
- Change: updated GPU monitoring code with latest version of ZoomGPU (1.5.11)
- Change: removed [Heavy PhysX mode] and [use particle count] checkboxes.
Link to comment
GPU-Z v0.4.9
  • Added support for GeForce GTX 570, GTX 460 SE
  • Added support for PCI-Express 3.0
  • Added PowerColor Giveaway
  • Added Colorfire PCI vendor ID
  • Added detection for AMD Radeon HD 6310, HD 6370
  • Fixed BIOS >64k reading on GF110
  • Added GT215 based GT 220
  • Fixed TMU count on GF104
  • Improved default clock reading on GeForce GTX 580
  • Better error handling for memory type detection code
Link to comment
GPU-Z 0.4.9
- Added support for PCI-Express 3.0
- Added PowerColor Giveaway
- Added Colorfire PCI vendor ID
- Added detection for AMD Radeon HD 6310, HD 6370
- Fixed BIOS >64k reading on GF110
- Added GT215 based GT 220
- Fixed TMU count on GF104
- Improved default clock reading on GeForce GTX 580
- Better error handling for memory type detection code
Link to comment
HWiNFO32 v3.65
- Enhanced support of ATI PM2 sensors.
- Added support of CHiL CH8266 PWM (for monitoring of GPU voltage, current, power).
- Added universal support of CSMI SAS (improved drive detection).
- Enhanced sensor monitoring on ASUS Rampage III GENE/Extreme.
- Added support of Intel XTU v2.1.
- Enhanced sensor monitoring on Intel 6-series desktop boards.
- Added nVidia GeForce GT 540M.
- Enhanced support of Ivy Bridge-DT/MB.
- Added preliminary support of Ivy Bridge-EP/EX (Ivytown).
- Enhanced sensor monitoring on MSI GX620.
- Improved recognition of Arrandale ECC.
- Added support of SMSC SCH3112/4/6 LPC HW monitor.
- Fixed Benchmark comparison label issue.
- Added Intel Core 2nd generation logos.
Link to comment
EVGA Precision 2.0.2
- Fixed issue in the context help system causing it to display wrong floating tooltips when hovering cursor over the controls under certain conditions
- EVGA On-Screen Display server has been upgraded to version 4.0.0. New version gives you the following improvements:
Reduced On-Screen Display rendering related CPU performance hit due to more effective geometry batching in On-Screen Display 3D rendering mode codepath
Now EVGA On-Screen Display server supports RivaTuner's user extendable localization system
Screenshot compression library SaveImage.dll has been replaced with more progressive SaveMedia.dll library providing unified screenshot and video encoding engine
JPEG screenshot quality settings are no longer power user oriented and can be adjusted directly from the client application GUI
Screen capture implementation is now multithreaded to minimize the impact on the game performance when saving screenshots on the systems with multicore CPUs
Text indication of screen capture events in the On-Screen Display has been replaced with graphics progress indicator
Fixed issues causing the On-Screen Display to be rendered in wrong colors in 3D mode in some multitextured Direct3D9 applications (e.g. several bumpmapping related samples from DirectX 9 SDK)
Updated profiles list
- Added option allowing hiding On-Screen Display on captured screenshots
- Reduced hardware polling time on multi-GPU systems due to cached GPU context switching in hardware monitoring module
- All synchronization mutexes have been moved from local to global namespace
- Added programmable alarm system allowing the Precision to play alarm sound when any monitored parameter is out of range defined by user
- Localization reference guide documentation has been updated to v1.2
Link to comment
HWiNFO32 v3.67
- Fixed measuring of CPU clock on certain AMD CPUs under Windows 7.
- Improved displaying of CPU and GPU logo.
- Improved measurement precision of CPU Power consumption on Ibex Peak and Sandy Bridge platforms.
- Fixed recognition of Sandy Bridge K-series when used on platforms other than P67.
- Added Smart Battery monitoring into sensors.
- Enhanced sensor monitoring on ASRock P67 and H67 series.
- Added reporting of BIOS EFI capability.
- Enhanced sensor monitoring on ASUS P8P67, P8H67 and SABERTOOTH P67 series.
- Enhanced sensor monitoring on ASUS Maximus IV Extreme.
- Enhanced sensor monitoring on GIGABYTE P67 and H67 series.
- Enhanced sensor monitoring on ASUS G73SW.
- Fixed possible GPU/Display issues on HP 8730w (caused by GPU I2C).
- Fixed reporting of GPU clock on some nVidia G9x-based GPUs.
Link to comment
GPU-Z v0.5.1
Changelog
  • Added support for NVIDIA GTX 560 Ti, 480M, 485M
  • Added transistors and die size for 460M, 445M, 435M
  • Added release date for 6800 GT, 6600 GT, 6600, 6200, 8800 GTX, 8800 GTS, 8800 Ultra, 8600 GTS, 8500 GT, 8800 GS, 9600 GSO, 8800 GT, GTS 250, GT 440
  • Added preliminary support for AMD Zacate and Ontario APUs
  • Found a new way to disable NVIDIA's power limiter
  • Added support for GTX 570 and GTX 560 to power limit disable function, the parameter is now called /GTX500OCP
  • Fixed crash in sensors panel
  • Acer PCI vendor now using a shorter text that fits the field width
  • Added CHL8214 & CHL8226 support for AMD Barts and Cayman
  • Improved the automatic update check to run completely in the background and only appear when an update is available (manual update check is unchanged)
Link to comment
iTunes 10.1.2
About iTunes 10.1.2
iTunes 10.1.2 provides a number of important stability and performance improvements.
iTunes 10.1 came with several new features and improvements, including:
* AirPlay to instantly and wirelessly stream videos from iTunes to the all-new Apple TV.
* Sync with your iPhone, iPad, or iPod touch with iOS 4.2. For information on the security content of this update, please visit: support.apple.com/kb/HT1222
SHA1 for Mac: 75304d4f16f8a790f5a819b04a59b98b563a062f
SHA1 for Windows 32 bit: b3d91fc83c51f2d01c1ff754b46a5ae5e8187642
SHA1 for Windows 64 bit: 68d6da0cf38554c451c7914f8ad82003f8d65798
EDIT: Μετέφερα το post στις Καινούριες Εκδόσεις, οπότε ας μεταφέρει κάποιος moderator το συγκεκριμένο στη μαύρη τρύπα.
Link to comment
  • 4 weeks later...
