  • Replies 748
Speccy v1.05.183
  • - Support for newest Intel and AMD CPUs.
    - Added GFX driver version to summary panel.
    - Improved NVidia SLI status detection.
    - Hard disk info now includes serial number.
    - Improved HD drive type detection for AMD Phenom motherboards.
    - Added "Check for updates" link to status bar.
    - Internet connection test added.
    - Added support for Hungarian language.
    - Uninstall now removes older 32-bit installations correctly.
    - Improved uninstall to remove dmp and log files.
    - Minor tweaks and improvements.
Real Temp ωερ 3.60
- added Core i Turbo multiplier and Turbo TDP/TDC overclocking for Extreme / K series CPUs
- added ATI GPU and improved Nvidia GPU monitoring with CrossFire and SLI support..
- added a system tray / notification area font selector.
- new Fahrenheit and 3 digit system tray option.
- fixed Core 2 Extreme multiplier reporting.
- fixed Core 2 mobile CPU C0% based load reporting.
- changed how Core 2 Super Low Frequency Mode (SLFM) is reported.
- bug with Reset button on ATI systems fixed.
- RealTemp GT for the 6 core Gulftown CPUs was also updated.
- separate i7 Turbo GT multiplier monitoring tool for 6 core Gulftown CPUs added.
Core Temp 0.99.8.0
- New: Added Hibernation to Overheat protection options.
- Fix: Mobile Intel Core2 Quad processor recognition issues.
- Fix: Pentium Dual-Core E6000 series model detection was incorrect.
- Update: TjMax adjusted to 100c (Intel's specs) for 400 and 500 series Atom processors.
GPU-Z v0.4.7
changelog
  • Improved support for AMD Radeon HD 6850 and HD 6870
  • Added support for NVIDIA GeForce GT 430, GT 420
  • Fixed default clock reading on Fermi architecture cards
  • Added voltage controller support for Colorful iGame GTX 460
  • Added PCI Vendor detection for Colorful
  • Added TMU count and die size for GF106
  • Synchronization mutexes are global now
  • Improved stability when running multiple instances of GPU-Z / Fixed "the driver has been marked for deletion" error
HWiNFO32 v3.61
- Minor fixes and updates (Win7 type, MX16xx Ext1 temp, GPU enum, SNB GFX clock).
- Added possibility to disable sensor data logging for report file (avoids raising of memory usage during monitoring).
- Added support of ITE IT8728F, IT8781F, IT8782F, IT8783F LPC/Hardware Monitor.
- Improved enumeration of multiple GPUs via NVAPI.
- Added monitoring of HP Envy 17 and Pavilion dv6 / dv7 EC.
- Fixed CPU clock measurement on certain Windows 7 systems.
- Enhanced sensor monitoring on ASUS Rampage III GENE.
- Added support of Alerts for Sensor values when reaching customizable thresholds.
- Enhanced sensor monitoring on MSI MS-7592.
- Added reporting of BIOS Message for Award/Phoenix BIOS machines.
- Added possibility to report SMART data and monitor temperature for drives in Intel RAID Array.
- Added monitoring of HP Envy 15 EC.
- Improved sensor monitoring for Tyan S7025.
- Added preliminary Ivy Bridge support.
- Changed nVidia GPU I2C method to NVAPI by default (can be changed back to low-level via settings).
Ένα αρχειάκι του lab από που μπορώ να το βρω και να το κατεβάσω?Αυτό που το πετάμε στον explorer και εμφανίζεται στην μπάρα και μπρούμε να το πατάμε για να πηγαίνουμε μέσα στο lab όπου θέλουμε!!!Καταλάβατε?Πως αλλιώς να το εξηγήσω...!δεν ξέρω!:p
Nvidia Inspector 1.9.4
- added nv driver version to settings title
- improved app version in settings title
- displaying inherited global settings in game profiles on driver version 260+ (black gear icon)
- added "export current profile" feature
- added "export userdefined profiles" feature
- added "import userdefined profiles" feature
- added "quick bit value tester" feature to bit value editor
- some minor fixes
SpeedFan 4.42
- added full access to hardware monitor chips available on several Nvidia video cards (enabled I2C writes to allow fan speed control too)
- Intel QST now checks first for 2.0, then falls back to 1.0, if needed
- added support for external USB drives using JMicron controllers
- fixed fan speed computation for several Analog Devices chips (ADM1027, ADT7463, ADT7475, ADT7476, ADT7468, ADT7473, ADT7490) when configured for non standard number of pulses per revolution
- MUTEXes used to synchronize with other tools while accessing buses are now defined Global
- fixed CPU usage bars size on the main window
- enabled SMBus access on ICH10 and ICH10R, if needed
- if SpeedFan service is unavailable, a message dialog is shown and the program stops running
- added scan exceptions for Asus P5N-T DELUXE and Intel DX58SO
- SEND REPORT now includes a list of ACPI devices found
GPU-Z 0.4.8
- Updated TMU/Texture rate calculation method. Please report any errors in the forums
- Fixed memory clock monitoring on HD 6850, HD 6870
- Fixed label corruption on cards without any shaders
- Fixed rare CrossFire detection bug on ancient ATI drivers
- Added voltage monitoring fallback for ATI cards with unsupported voltage controller
- Updated PCI vendor ID for PowerColor
HWiNFO32 v3.62
- Added monitoring of fan speed on certain Toshiba notebooks (with TVALZ driver).
- Fixed Multi-GPU support in case of different brand/model GPUs.
- Enhanced support of Cedarview.
- Added patch for BSOD on multi-GPU machines in case ULPS powers down a GPU.
- Fixed rare hang during CPU scan caused by HPET timers.
- Enhanced sensor monitoring on Biostar TPower I45, MSI Big Bang-XPower (MS-7666).
- Enhanced support of some PMBus capable sensors.
- Added reporting of maximum supported PCIe and USB version on system.
