Fraps 3.2.1
- Fixed screen capture of large resolutions (ATI Eyefinity)
- Fixed counter disappearing in some games when switching resolution
- Improved recording speed on SLI configurations
- Other minor bug/crash fixes
  • Replies 748
HWiNFO32 3.45
- Enhanced support of Sandy Bridge family.
- Added IT87xx fan divisors setup if not configured properly by default.
- Added nVidia GeForce GTX 470 and GeForce GTX 480 (GF100 / Fermi).
- Fixed reading from AMB.
- Improved USB scan.
- Added possibility to automatically minimalize either the Main or Sensors Window. Can be used to display only Sensor data.
- Added possibility to report sensor values in Vista Sidebar.
- Added possibility to disable particular sensor scanning.
- Added possibility to autorun HWiNFO32 during Windows start.
- Improved reporting of CPU Power for IbexPeak-based platforms.
- Several other minor updates and bugfixes.
  • 3 weeks later...
FurMark 1.8.2
- New: different scoring web pages for version 1.7.0 and 1.8.2+.
- New: option to enable FurMark 1.7.0 compatibility mode.
- New: support of latest Radeon HD 5000 and GeForce GTX 400 series.
- New: display of GPU and memory clocks (even if GPU-Z is not started).
- Change: improved temperature graphs readability.
Core Temp 0.99.6
- Add: Better recognition of AMD dual/tri core unlocked CPUs.
- Add: Optional 24 hour display on G15 LCD.- Fix: Platform field blank for newer AMD CPUs.
- Fix: Some K8 CPUs were unknown or recognized incorrectly.
- Fix: Overheat protection "Activate at specified temperature" problems were fixed.
- Fix: Overheat detection does not show a Balloon Tip when user specified temperature value is set.
- Fix: Temperature displays a negative value when core temperature reaches over TjMax (Intel).
- Fix: Intel W3500 series Xeons recognized with Core i7 model numbers (ie W3520 shown as Xeon 920)
- Fix: In certain cases Core 2 Duo T5500 was recognized as a T5450.
- Fix: G15 LCD display is no longer always-on-top after coming out of sleep or hibernation.
- Fix: G15 won't display 0.0000v in case VID readings are not supported by the CPU.
- Fix: In some cases, at Windows startup systemtray icons would not appear.
- Change: Windows XP SP2 or higher is now required.
- Change: Completely new processor frequency detection algorithm. (for Core 2 generation and newer only)
- Change: Remove "APICID" from main window as it has very little use.
Memtest86+ v4.10
  • New Features
    • Added support for Core i7 Extreme CPU (32nm)
    • Added support for Core i5/i3 (32 nm)
    • Added support for Pentium Gxxxx (32 mn)
    • Added support for Westmere-based Xeon
    • Added preliminary support for Intel Sandy Bridge
    • Added support for AMD 6-cores CPU
    • Added detection for Intel 3200/3210
    • New installer for USB Key
    [*]Bug Fixes
    • Corrected a crash at startup
    • Many others bug fixes
GPU-Z 0.4.3
- Added full voltage controller monitoring for GeForce GTX 480
- Added real-time clock monitoring for GF100
- Added detection for vendor GALAXY
- Complete revamp of voltage controller architecture. Adds voltage monitoring for many ATI & NVIDIA cards and generic monitoring method for NVIDIA cards via driver.
- Added support for >4 GB memory on NVIDIA
- Fixed memory clock reading on some HD 5670 cards
- Fixed thermal sensor count on some ATI Evergreen models
- Fixed incorrect default clock reading on some ATI Evergreen models
- Added detection for NVIDIA GTX 465, GT 320M GT 335M, ION variant, GT 340, Tesla C2050, Tesla M2050, GTX 285M, GT 325M, Quadro FX 880M, Quadro FX 1800M
- Added detection for ATI HD 5570, Mobility 4550, Mobility 5870, HD 4250, HD 4290, FirePro V7750
- Added detection for Intel GMA 3150
- Added fix for ADT7473 coldbug (GTX 480) via commandline parameter /fixcoldbug
- Added OCP adjustment for CHL8266 (GTX 480). Use it via command line parameter /chl8266ocp without parameter to query, with numeric value seperated by space to set. This is a permanent change that will not be reverted by powering down the system.
- Added languages Hungarian and Spanish
- Updated languages French, Italian, Russian
PhysX FluidMark 1.2.0
- New: added a checkbox to set the number of particles.
- New: added a checkbox to force CPU PhysX.
- New: added Heavy PhysX mode: to make modern systems with GPU PhysX happy
- New: added point sprite based rendering for particles (keys F2, F3 and F4).
- New: added keyboard-based camera control in stability test mode.
- Change: compiled with NVIDIA PhysX SDK 2.8.3.21.
- Change: updated with the latest version of ZoomGPU for graphics hardware detection.
EVGA Precision 1.9.4
- Fixed D3D11 framerate display in Logitech keyboard LCD
- Fixed button saving issue on old Nvidia graphics cards caused by adding Fermi graphics cards support in v1.9.2
- Unlocked memory downclocking ability on GeForce GTX 400 series under the latest Nvidia drivers
- Startup profile is now displayed in option floating tooltip
- Floating tooltips help system is now reinitialized properly after runtime skin switching
- EVGA On-Screen Display server has been upgraded to version 3.7.1 featuring the following changes:
Improved On-Screen Display 3D rendering mode compatibility with Source engine based games and Star Trek Online
HWiNFO32 version 3.51
- Fixed possible crash after having graphs opened for longer time.
- Updated reporting of IDA capability.
- Added reporting of VIA P4M800 memory timings.
- Reduced ATI I2C sensor scan time.
- Added support of Atmel DIMM Temperature sensor.
- Improved sensor monitoring for MSI NF980-G65 (MS-7612).
- Improved reporting of GPU memory clock for AMD Evergreen family.
- Added nVidia GeForce GTX 465.
- Improved sensor monitoring for ASRock 890GX Extreme3 and 890FX Deluxe3.
- Improved sensor monitoring for ASUS NCCH-DL and NCT-D(A).
- Improved monitoring of CPU/PCH (Ibex Peak) power consumption.
- Improved monitoring of nVidia GPU diode temperature.
- Added monitoring of nVidia GPU Fan duty cycle.
GPU-Shark 0.2.0
- New: added memory usage for NVIDIA cards.
- New: added the TDP (thermal design power) if available.
- New: added subvendor names: ASUS, Palit and Gigabyte.
- Change: removed the flickering effect that occured at each update.
- Change: when graphics drivers are not supported, GPU-Shark tries to display only OpenGL information.
- Change: Caption in View menu: Detailed mode or Simplified mode.
- Change: vertical scrollbar a bit shorter.
HWMonitor Pro v1.0.9
This version adds the following :
- New sensor chips : Fintek F71862, F71869, F71889, F81865, CHIL CHL8266, ITE IT8721, Analog Device ADM1033.
- Intel QST 2.0.
- Asus ROG monitoring.
- Gigabyte DES monitoring
MSI Afterburner 1.6.0
- Added Nvidia GeForce GTX 400 series graphics cards support (including voltage control!)
- Added voltage control for MSI N240GT Low Profile series graphics cards
- Changed marketing name for MSI R5670-PD512 in hardware database
- Added basic screen capture support by means of built-in screen capture engine of MSI On-Screen Display server. Now it is possible to assign the hotkey for capturing screenshots in BMP,PNG or JPG formats on desktop, in DirectX or in OpenGL applications
- Added hardware monitoring history logging support. Now MSI Afterburner is able to save history in native RivaTuner Hardware Monitoring Log file format.
- Added new safety option allowing forcing constant voltage on some cards with voltage regulators supporting programmable dynamic voltage management (e.g. VT1165 or uP6266).
- Screen capture and On-Screen Display hotkey events are now being processed via direct connection to the On-Screen Display server instead of command line.
- MSI On-Screen Display server has been upgraded to version 3.7.1. New server gives you a lot of improvements including:
- DirectX11 On-Screen Display and screen capture support
- DirectX screen capture engine is no longer using DirectX runtimes to capture and compress screenshots. Screen capture and compression to PNG/JPG formats in DirectX applications is now handled by own more effective LIBPNG/JPEGLIB based library
- PNG and JPG screen capture support for desktop and OpenGL applications
- Adjustable JPG screen capture quality for experienced users
- Screen capture support for DirectX10 and DirectX11 applications using multisampled antialiasing or non-standard frame buffer formats (e.g. sRGB)
- Optional On-Screen Display 3D rendering mode. New mode uses 3D accelerated DirectX functions to emulate previously used 2D framebuffer access functions and render 2D text. New rendering mode provides On-Screen Display support in DirectX10 and DirectX11 applications using multisampled antialiasing and can also drastically reduce OSD related performance hit on the systems with badly optimized 2D acceleration in display drivers
- Simplified On-Screen Display coordinate space settings. Rarely used desktop and window coordinate space modes have been merged into single framebuffer coordinate space mode
- Improved application notification scheme during runtime profiles adjustment. Now runtime changes in OSD application profiles (e.g. OSD zoom ratio change on the fly) are reflected in affected application almost immediately instead of approximately 1 second delay in the previous versions
- Reduced runtime skin engine memory footprint due to dynamic skin storage unloading
Improved race condition protection system for multithreaded 3D engines (e.g. Age of dragons : Origins and ArmA II)
- Improved race condition protection system for the systems running multiple OSD applications simultaneously (e.g. OSD server, FRAPS and STEAM In-Game Chat)
- Improved floating injection address hooking technology. Due to more advanced built-in code analyzer hooks can be injected deeper into 3D application code if stealth mode is enabled.
- Now stealth mode cannot be toggled during 3D application runtime to reduce the risk of crashing 3D application
- Removed single screen capture per second limitation
- Updated profiles list
- Now MSI Afterburner distributive includes original 128x128 PNG application logo (stored in .\Graphics folder) for dockbar applications like RocketDock or ObjectDock
- It is no longer necessary to close the application to save monitoring window attachment state
[stop the task if it runs longer than 3 days] option is no longer set in the task settings when using alternate startup mode via the task scheduler under Windows Vista / Windows 7
- Full list active of On-Screen Display server clients is now displayed in {i} window instead of the most recent client
- Added Ukrainian localization
Fraps 3.2.3
The main thing brought by Fraps 3.2.3 is the ability for full-size video capture above 2560 x 1600 pixels, while its bug log looks a little something like this:
- Fixed crash when loading Fraps under WinXP with 6-core CPU
- Fixed crash when enabling monitor DWM option on some configurations
- Fixed Fraps altering error flag on calls to GL SwapBuffers
- Fixed sound input switching at startup on XP systems
- Fixed counter appearing in VS2010
