sofos1990 Ιούλιος 7, 2009 #561 Ιούλιος 7, 2009 HWiNFO32 v3.01-326Changes * Updated reporting of Tcas and Trtp for Nehalem IMC. * Added EVGA X58 SLI motherboard specific sensor support. * Improved recognition of some LPCs. * Added reporting of max Turbo Operating Point for non-XE Nehalem CPUs. * Added nVidia GeForce G 105M and GeForce GT 220M. * Fixed reporting of current ratio and BCLK for Nehalem in Turbo Mode. * Fixed reporting of current Uncore and QPI clock on overclocked Nehalem. * Added nVidia N10E-GLM, N10E-GLM3, N10E-GS, N10P-NS, N10P-GLM, N10M-GLM, GeForce GTS 150M, Quadro NVS 170M (GT218). * Several other minor updates and bugfixes.
def Νοέμβριος 7, 2009 #562 Νοέμβριος 7, 2009 http://en.expreview.com/2009/11/07/fraps-300-available-for-download.htmlαν επρεπε να μπει αλλου παρακαλω να μετακινηθει:daisy:
hayabusa Δεκέμβριος 24, 2009 #563 Δεκέμβριος 24, 2009 GPU Caps Viewer 1.8.1 - Change: added the use of the GL interop preview available in ATI Stream SDK v2.0.0 for Julia 4D and 1M Particle demos. Due to some instability, the GL interop is not enabled by default. To enable GL interop, start GPU Caps with the batch file Start_OpenCL_With_GLInterop.bat.- New: added a command line parameter to disable OpenCL support (/disable_cl_support).- Bugfix: added the specification of context properties in clCreateContextFromType (instead of NULL) for ATI Stream SDK v2.0.0.
hayabusa Φεβρουάριος 3, 2010 #564 Φεβρουάριος 3, 2010 FurMark 1.8.0 - New: now all options are available in benchmarking mode: Xtrem Burning, postfx (FX) and displacement mapping (DM). - New: added new effet (displacement mapping) on the fur rendering. - New: GUI translation is done with XML files in the localization folder. - New: added hotkeys: P to enable/disable post fx rendering, T to enable/disable temperature graphs rendering. - New: GPU temperature is now exported in xml and csv formats. - New: twitter submission displays a login dialog box to tweet your score. - Change: the fur rendering workload has been increased to produce more heat. - Change: improved temperature graphs readability. - Change: updated with the latest version of ZoomGPU for graphics hardware detection. - Change: A cool new background image.
g1ann1s Φεβρουάριος 8, 2010 #565 Φεβρουάριος 8, 2010 Benchmark.. παρόμοιο με το superpi http://www.maxxpi.net/pages/description/multipi.php ###### [sTART 1M batch: 8/2/2010 - 10:40:47] ###### [1] - [1M score: 1137.9 K/sec.] - [00:00:00:899:885] - [OK!] [2] - [1M score: 1148.1 K/sec.] - [00:00:00:891:929] - [OK!] [3] - [1M score: 1152.2 K/sec.] - [00:00:00:888:758] - [OK!] [4] - [1M score: 1163.5 K/sec.] - [00:00:00:880:090] - [OK!] [5] - [1M score: 1143.5 K/sec.] - [00:00:00:895:512] - [OK!] [6] - [1M score: 1151.7 K/sec.] - [00:00:00:889:096] - [OK!] [7] - [1M score: 1168.2 K/sec.] - [00:00:00:876:539] - [OK!] [8] - [1M score: 1173.2 K/sec.] - [00:00:00:872:858] - [OK!] _____________________________________ Average 1M score: 1154.8 K/sec. Deviations from average: -1.5% / +1.6% ――――――――――――――――――――――――――――――――――――― ###### [sTOP 1M batch: 8/2/2010 - 10:41:09] ###### ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
hayabusa Φεβρουάριος 24, 2010 #567 Φεβρουάριος 24, 2010 GPU-Z 0.3.9- Added localized tooltips in the languages: AM, AR, BG, CN, DE, FA, FR, IT, PT, RS, RU, TR, UA.- Added support for ATI Radeon HD 5830, HD 5770, HD 5750, HD 5670, HD 5570, HD 5450, HD 4860, HD 4750, Mobility HD 3430, M97, Mobility Radeon HD 5850, 5730, 5650, 5470- Added support for Nvidia GeForce 6200A, GTS 250, 9800S, 205, 310, GT 320, GT 240, GTS 360M, 230M, 330M, 240M, G105M, Quadro NVS170M, G210M, GTS 250M, future MCP, more ION variants.- Added support for Intel GMA500, Clarkdale, Arrandale- Added detection for variants of NVIDIA NV41, G94, G98, ATI RV350, RV370, R480, RV515.- Improved default clock BIOS parsing on Nvidia- Fix for incorrect default clocks on HD 5000 Series- Fixed incorrect real-time clock monitoring on some HD 5000 cards- Added more accurate real-time clock monitoring function for Nvidia- Improved OpenCL detection on ATI R700, RV790, all HD 5000 cards- Added temp. monitoring support for some Intel IGPs- Improvements to CUDA detection- Removed memory chip input fields from VGA BIOS Upload
hayabusa Μάρτιος 3, 2010 #568 Μάρτιος 3, 2010 HWiNFO32 3.43- Fixed IT8712 fan tachometer reading.- Improved reporting of Single/Dual-channel Memory detection for K10.- Improved SCSI device scan.- Improved benchmark disk selection.- Improved calculation of BCLK for Nehalem CPUs.- Updated reporting of Tcas for Clarkdale/Arrandale.- Improved measuring of CPU clock using HPET if available.- Added QST 2.0 monitoring support.- Added support of secondary LPC.- Improved sensor monitoring for EVGA W555.- Added VIA VN1000 chipset support.- Added option to select driver persistance.- Updated help file.- Improved sensor monitoring for ASUS M2N-SLI Deluxe.- Improved sensor monitoring for MSI DKA790GX Platinum (MS-7550).- Improved support of AMD 890GX and SB800/Hudson.- Enhanced support of VIA VT8261.- Improved sensor monitoring for ASRock series: P43DE2, P43iCafe, 770 Extreme3, 770iCafe, M3A790GXH/USB3, 880GMH/USB3, 890GMH/USB3, 890GX Extreme3.- Improved sensor monitoring for ASUS series: M4A89GTD-PRO, M4A89GTD-PRO/USB3.
hayabusa Μάρτιος 4, 2010 #569 Μάρτιος 4, 2010 GPU Caps Viewer 1.8.4- New: added GeForce GT 320/330/340, Radeon HD 5450, HD 5830 and HD 4290 (AMD 890GX) to GPU database.- New: GPU clocks reading is now regularly updated (interval = 2sec).- Change: updated with PhysX 2.8.3 SDK.- Change: temperature reading for ATI graphics cards.- Change: clocks reading for ATI graphics cards (now for example, under WinXP, Radeon HD 4850 clocks are displayed).- Bugfix: number of geometry shader texture units was wrong in OpenGL tab.- Bugfix: crash in first panel when an OpenCL platform had no OpenCL device…
Arxagelos Μάρτιος 23, 2010 #570 Μάρτιος 23, 2010 Unigine Heaven 2.0 RC1 leakhttp://www.megaupload.com/?d=DXLT34HS
Cube8 Μάρτιος 23, 2010 #571 Μάρτιος 23, 2010 Τι πρόγραμμα είναι αυτό?(ξέρω ότι μπορώ να ψάξω στο γούγλη, αλλά το σωστό είναι να δίνουμε και μια σύντομη περιγραφή)
Arxagelos Μάρτιος 23, 2010 #572 Μάρτιος 23, 2010 3D bench ειναι για κάρτες γραφικών και το πρώτο που υποστήριξε DX11 και tesselation. Επίσης διαβάζω οτι η unigine είναι και μηχανή γραφικών που θα χρησιμοποιηθεί σε μελλοντικά παιχνίδια.
hayabusa Μάρτιος 25, 2010 #573 Μάρτιος 25, 2010 CPU-Z 1.54 - Intel Core i7-880, Core i5-680, Core i3-550 processor support.- Intel Xeon 5600 line (32nm) processor support.- AMD Phenom II X6, Sempron II, Turion II, Turion II Ultra and Athlon II Mobile "Caspian" processor support.- Nvidia GeForce 320M chipset support.- AMD 870/880G/890GX + SB800/SB850 chipset support.- Introduction of validation rooms.
hayabusa Μάρτιος 26, 2010 #574 Μάρτιος 26, 2010 GPU Caps Viewer 1.8.6New: added the TDP (thermal power design) for recent NVIDIA and ATI graphics cards.New: added the number of SM (NVIDIA) or SIMD (ATI).Bugfix: GL 3.x demos could not start with and GL 4.0 context…Bugfix: Windows version detection (Windows XP, Windows Vista or Windows 7).Bugfix: in main panel, the clock speed of CUDA engines was wrong.Bugfix: in the OpenCL surface deformer demo, the type (size_t) of some kernel arguments has been replaced by unsigned int.
hayabusa Μάρτιος 27, 2010 #575 Μάρτιος 27, 2010 GPU-Z v0.4.0- Added support for NVIDIA GeForce GTX 470 and GTX 480- Added voltage monitoring for HD 5750, 5830, 5870 Lightning- Added support for Intel Pineview- Fixed double memory clock reading on NVIDIA w/ GDDR5 (real clock is now displayed)- Fixed rounding errors in RV7xx and Evergreen fan monitoring code- Added tooltip translations for Albanian and Chinese Traditional- Memory bandwidth calculation uses GB now instead of GiB
GoMaR Μάρτιος 27, 2010 #576 Μάρτιος 27, 2010 πολυ σπαμμερ αυτος ο hayabusas βρε παιδι μου btw , δωστε του καμμια ειδικοτητα "tool searcher"
hayabusa Μάρτιος 29, 2010 #578 Μάρτιος 29, 2010 Fraps to v3.2.0 improve its use with the latest DirectX 10 and DirectX 11 games. In addition to recording optimizations, Fraps 3.2.0 brings an option to disable stereoscopic capture when running with Nvidia 3DVision and, only for registered users, the a loop recording feature which will continuously capture 30 second clips.
Cube8 Μάρτιος 29, 2010 #579 Μάρτιος 29, 2010 Κύριε spammer-hayabusa , καμιά πληροφορία για το πρόγραμμα? Version news?
