CoreTemp 0.99.1
Version 0.99.1 - 10th July, 2008
- Fix: Layout when using upto 125% DPI.
- Fix: Layout problem and extra systemtray icons with Phenom.
- Fix: Potential crashes while saving a register dump file.
- Fix: Core Temp icon wasn't showing in About box.
- Fix: Menu shortcut keys were not available for all menu items.
- Fix: A few old unnoticable bugs.
- Add: Initial Intel Nehalem support.
- Add: Initial support for AMD's Griffin cores - Untested.
- Add: Improved Intel Atom support.
- Add: Support latest AMD K8 CPUs.
- Add: Support for HyperThreaded CPUs. Core Temp will only display the physical cores and average load on each core.
- Add: Support for Pentium E5000 series.
- Add: Display core and thread count per CPU.
- Add: GUI Adjustments of Temperature offset and G15 applet via the Settings window.
- Add: Create a screenshot function. Access from "Options" menu or by F9 shortcut.
- Add: Shortcut key for register dump file: F7.
- Add: Update register dump output: APIC ID, CPU number, Core number, Thread number.
- Change: Move all settings to the ini file out of the registry.
- Change: Rename ini file to CoreTemp.ini.
- Change: Temperature offset adjustment works for AMD CPUs as well.
- Change: Atom Tj.Max adjusted for more accurate readings.
- Change: Cleaned up code a little bit.
  • 4 weeks later...
  • Replies 748
CoreTemp 0.99.2 ready for download
Fix: Start with Windows option was broken in 0.99.1.
- Fix: Default color for the second system tray icon is invisible with WinXP blue theme.
- Fix: Save screenshot function would create a corrupted BMP in some viewing software.
- Fix: Nehalem does not report VID like earlier CPUs. VID field now disabled for Nehalem.
- Fix: Incorrect 65nm Turion X2 code name detection.
- Fix: Potential bug of improper K10 and up recognition.
- Fix: Enabling distance to Tj.Max with "Highest temp." for system tray would show the largest distance to Tj.Max instead of smallest.
- Fix: Vendor ID and Device ID values were reversed in the register dump file.
- Fix: 3/4 temperatures logged for Phenom X3/X4 instead of 1.
- Add: Support for Core Temp plugins. (currently in beta)
- Add: Full support for AMD's Puma platform CPUs.
- Add: Initial support for 45nm AMD processors.
- Add: Update K8 and K10 recognition code to support all currently known CPUs.
- Add: Default TDP detection for Nehalem.
- Add: On the fly CPU speed detection.
- Add: Close to system tray option.
- Change: Log file is now produced in CSV format - easily import your logs into Excel.
- Change: Logging interval is now in Seconds instead of miliseconds.
- Change: Default logging interval is now 10 seconds.
- Change: Logging is now off by default.
Το μόνο πρόγραμμα που δεν έχει κανένα πρόβλημα σε μένα σε Vista64 είναι το realtemp.
To coretemp έχει προβλήματα πρόσβασης σε περιοχές της μνήμης που επηρεάζουν το BIOS και είναι αιτία αστάθειας.
H Intel μόλις ανακοίνωσε επίσημα το max tjunction για τους 45nm επεξεργαστές, οπότε θα δούμε νέες εκδόσεις όλων των προγραμμάτων που υπολογίζουν θερμοκρασίες από το DTS (digital thermal sensor).
Speedfan 4.35
4.35
* released to the public the EXOTICS tab
* fixed 120 DPI issue in CONFIGURE dialog
* added full support for Areca RAID controllers
* greatly improved SCSI support
* added support for Abit uGuru 3 (uGuru 2005)
* added full support for Intel FB-DIMM temperature readings
* added full support for ITE IT8720F
* added full support for Andigilog aSC7611
* added full support for LM96000 (it was previously detected as LM85B)
* added full support for Analog Devices ADT7490
* added full support for SMSC SCH5327
* fixed Windbond W83766HG hardware monitor detection on some Asus motherboards
* improved CPU identification routines
* added support for a new revision of the WINBOND W83637HF
* added support for WINBOND W83637HF at unusual addresses
* added support for Asus F8000 at unusual addresses
* added identification of the SMSC SCH5514
* added identification of SMSC EMC2300
* added ITE IT8718F fifth fan speed reporting
* added identification of Analog Devices ADP3228
* added identification of ITE IT8512F
* added identification of Winbond W83667HG SuperIO chip
* identified a new revision of Fintek F71872 hardware monitor subsystem
* added preliminary detection of the HECI driver
* fixed a bug in SMSC LPC47M172 support code that prevented fan speeds to be properly reported
* 45nm Intel CPUs with CPUID=0x10676 now use a Tjmax value of either 105C or 90C
* added full support for nVidia MCP65 SMBus
* added full support for nVidia MCP67 SMBus
* added full support for nVidia MCP73 SMBus
* added full support for nVidia MCP78S SMBus
* added full support for VIA CX700M SMBus
* added full support for Intel 82801JIB SMBus
* fixed an issue where the Intel SMBus couldn't be accessed and messages like SMBus msg : SMB Error $14 : FAILED (50) were generated
* enabled Intel ICH8M-E SMBus device, if needed
* enabled 631xESB SMBus, if needed
* enabled SMBus on Intel ICH9R, if needed
* preliminary detection of AMD CD5536 SMBus
* some SMBus addresses on Asus Striker Extreme are no longer scanned
* SMBus is no longer scanned at address $2E on DELL XPS710
* Tyan S2927 second SMBus is no longer scanned
* some addresses on the SMBus of Asus P5NT WS are no longer scanned
* some addresses on the SMBus of the Intel DX38BT are no longer scanned
* some SMBus addresses are no longer scanned on Asus M2N32-SLI DELUXE
* the second nForce SMBus is no longer scanned on FIC AU31
* some addresses on the SMBus of Supermicro H8DCE are no longer scanned
* added some SMBus scan exclusions for Intel D5400XS
* added /NOGIVEIO command line parameter to disable access to giveio.sys
* added /NOGEFORCEROM command line switch that will prevent SpeedFan from reading nVidia GeForce ROMs (useful if it takes too much time)
* nVidia video BIOS is now stored in a file for later retrieval
* fixed an access violation under Win9x with some nVidia video cards
* battery status messages are no longer displayed
* upon resume, all controlled fans are set to 100% for half a second, then set to their minimum fan speed
* added new configuration option SHOWSTATICICON
* enabled Intel 6300ESB SMBus if needed
http://www.almico.com/sfdownload.php
CoreTemp 0.99.3
Version 0.99.3 - 22th August, 2008
- Add: Correct TjMax values for 45nm Core 2 series, according to this document.
- Fix: When TjMax = 0 (undefined) "Delta to Tjunction" was not added to the temperature string.
- Fix: On the fly CPU speed didn't pick up changes when EIST was disabled (only C1E active).
  perp έγραψε:
CoreTemp 0.99.3
ιδιες με πριν ειναι οι θερμοκρασιες στον yorkfiled. Μονο στους διπυρηνους 45αρηδες το αλλαξε?
  • 3 weeks later...
GPU-Z 0.2.8 ready for download
Added logging of sensor data to file
- Added option to disable polling for individual sensors
- Added support for AMD RV730
- Added clock reading support for Catalyst 8.9 on RV770 and RV730
- Added support for NVIDIA 9400 GT, 9500 GT, 9600 GS, 9800M GS, 9600M GS, 9300M GS, 9200M GE
- Added support for AMD R580 Stream Processor, RV730 and one M88 variant
- Fixed PCI subvendor ID 1787 to be ATI AIB
- Fixed readings and added monitoring support for ATI M88
- Fixed fan speed readings on ADT7473 sensor
- Added support for ADT7473 sensor chip on ATI
- Added release dates for several NVIDIA mobile GPUs
  • 3 weeks later...
cpu-z 1.48
* Improved support for Intel Core i7 (Bloomfield & Gainestown).
* Intel Atom dual-core version support.
* AMD Athlon "Kuma" processor support.
* Alternate clock computation method based on "duty cycles" for Intel Core 2 processors (see ShowDutyCycles in cpuz.ini)
  • 2 months later...
MemTest86+ 2.11
- Added support for Intel Core i5 (Lynnfield) CPU
- Added support for Intel P55 Southbridge
- Added support for Intel PM45/GM45/GM47 Mobile chipset
- Added support for Intel GL40/GS45 Mobile chipset
- Corrected DDR2/DDR3 detection on Intel x35/x45
- Corrected detection on some Core i7 CPU
- Fixed a bug with some AMI BIOS (freeze at startup)
- Various bug fixes
Riva Tuner V 2.21
# Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 180.60, 180.70 and 180.84.
# Added Catalyst 8.12 driver family detection.
# Added 'Enable FOURCC INTZ surfaces' and 'Enable FOURCC RAWZ surfaces' options to the 'Textures' tab of the Direct3D tweaks dialog.
# 'Restore after suspended mode' option in low-level fan control tab is multi-GPU oriented now. Now the option affects all display adapters in the system instead of currently selected display adapter only.
# 'Allow separate 2D/3D clock frequency adjustment' option is no longer provided when enabling driver-level hardware overclocking. The option is now hidden to reduce the amount of false bugreports posted by the beginners trying to disable 2D/3D clock frequncy then claiming that the hardware stays at extremely low boot clocks. Power users can still control this option via AllowMaxPerf registry entry.
# Extended list of detectable supported FOURCC formats in 'IDirect3D9 HAL adapter formats' diagnostic report category.
GPU-Z 0.3.1 up
- Fixed crash on systems without NVAPI (Win 2K, old NV drivers)
- Optimized RV770 BIOS reading code for speed (faster application startup)
- Improved voltage reading code for recent ATI cards
- Added support for fan speed monitoring on ForceWare 180.xx and up
- Added voltage monitoring for NVIDIA (GT200)
- Changed reading method for RV770 sensors, fixes race conditions with other software and on-board fan control
- NVIDIA 9800 GTX+ listed as 55nm now
- Added support for Intel Q43/Q45
- Added support for NVIDIA Quadro FX 4700 X2, GTX 295, GTX 285
- Added preliminary support for NVIDIA GT212, GT214, GT215, GT216, GT218
  • 3 weeks later...
Core Temp 0.99.4 - 19 Ιανουαριου, 2009
Major changes:
Completely rewritten base code.
Core Temp is now available in both 32 and 64 bit versions.
- Add: CPU detection improved, efficiency improved, speed improved, clock speed detection improved.
- Add: Initial support for Core i5 (Lynnfield).
- Add: Automatically detect Core i7/i5 series TjMax.
- Add: Show real-time TDP of Core i7 processors (still needs work).
- Add: Alternative clock speed detection for Core 2, i7 and i5 series and up.
- Add: Support for all currently available and some future processor families. (Intel & AMD)
- Add: Temperature changes color when temperatures hit high levels to alert the user. (Orange = hot, Red = critical)
- Add: Show (!) besides the temperature of a core which hit critical temp as a notification of past overheating.
- Add: Invalid temperature values are followed by (?) for both Intel and AMD.
- Add: AMD AM2+ 65nm processors get a 21c offset to fix incorrect temperature reporting (info from AMD).
- Add: AMD Black Edition processors identified by "BE" suffix after PR rating.
- Add: Display time and date on G15 LCD.
- Add: Complete DPI awareness - Core Temp GUI now scales perfectly with any DPI setting.
- Add: Rewritten algorithm for "Register dump" function, works much faster and more accurate (no ghost devices).
- Add: Redesigned log file system:
1) Settings window allows to start logging when Core Temp starts.
Logging can be toggled on or off from the Options menu or simply by pressing F4.
2) Layout is completely changed. Now it's easy to create graphs and the output is more coherent and understandable.
3) CSV file format is preserved.
4) Each logging session creates a seperate log file named with time and date of session start.
5) Logging is now off by default.
- Add: Register dump provides much more information:
1) Supported instruction set.
2) Supported features.
3) Manufacturing node.
4) Default CPU speed, multiplier range and maximum VID.
5) Bus ratio multiplier.
6) Bus frequency.
7) Processor and OS thread counts.
8) Cache: Count and size.
9) Processor topology.
10) PCI register dump also lists device names when "PCIDEVS.TXT" file is added to Core Temp's directory, Link (scroll down a little).
11) Better output layout, easier to read.
- Fix: Core Temp crashes on Intel multi-processor platforms with Socket #0 unpopulated.
- Fix: Countless minor bug fixes due to rewritten code base.
- Fix: System tray icons do not appear after explorer.exe crash/restart.
- Change: Core Temp will now work with A0 and A1 revisions of 65nm Core 2 processors.
- Change: Core Temp will not work on some/all virtual machine software.
- Change: TjMax values for 65nm Core 2 series adjusted.
