HWMonitor 1.08 dated 14/Mar/08
<table border="1" cellpadding="4" cellspacing="0" width="100%"><tbody><tr><td valign="top">1.08</td> <td valign="top">03/14/2008</td> <td valign="top">
  • Min/Max values.
  • 64-bit version for Windows XP64, Server 2003 64-bit and Vista 64.
  • Several bug fixes.
</td></tr></tbody></table> <table border="1" cellpadding="4" cellspacing="0" width="100%"><tbody><tr><td valign="top">1.07</td> <td valign="top">02/08/2008</td> <td valign="top">
  • ACPI Thermal Zones support.
  • FB-DIMM integrated thermal sensor (Intel® 5400A/B MCH only).
  • New sensors ICs : Analog Device® ADM1021, ADM1027, ADM1030.
</td></tr></tbody></table> <table border="1" cellpadding="4" cellspacing="0" width="100%"><tbody><tr><td valign="top">1.06</td> <td valign="top">12/29/2007</td> <td valign="top">
  • New interface.
  • Replies 748
GPU-Z v0.1.9
* Fixed bluescreen when GPU-Z is started
* Fixed splash screen not going away in some cases
* Fixed crash when GPU registers couldn't be accessed (thanks tDJ)
* Fixed shader count for NV44
CoreTemp 0.99 Final released
download link
- Fix: Incorrect recognition of 45nm Mobile Intel CPUs.
- Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1).
- Fix: CPU load would sometimes display -1% load.
- Fix: AMD K8 would sometimes spike to 206C, the false reading is now ignored.
- Fix: AMD K8 sometimes constantly reads -49C.
- Fix: Core Temp does not show up automatically on G15 LCD with 2.02 driver.
- Fix: Shared memory structure was not properly filled on multiprocessor systems.
- Fix: System tray setting "Show highest temperature of each CPU" only displays one temperature reading in a multi CPU system.
- Fix: Certain problems with font resizing should now be fixed.
- Fix: G15 LCD would not update after using soft buttons.
- Fix: On temperature display mode change, high and low records were not reset.
- Fix: Changing the reading interval in settings did not actually update, restart of Core Temp was needed to apply the change.
- Fix: Incorrect VID detection on 45nm desktop Intel parts.
- Add: Shared memory - developers now have access to Core Temp data.
- Add: Register dump to text file function.
- Add: Preliminary Atom (Silverthorne) support - Untested.
- Add: Support for Intel Core 2 Duo E7000 45nm series.
- Add: Option to show a single icon instead of temperature in the system tray.
- Add: Custom font and size for G15 LCD screen or simply use the built in compact font and layout. (via Settings.ini)
- Change: Improved detection of L2 cache on Intel chips for more accurate recognition.
- Change: Rewritten temperature calculation to fix problems with shared memory.
- Change: Default G15 LCD text layout and font changed.
- Change: Doesn't create a log file containing session start and end times if logging is disabled.
- Change: Settings.ini file is automatically created with default settings in case one doesn't already exist.
GPU-Z 0.2.2 ready for download
http://www.techpowerup.com/downloads/1077/mirrors.php
- Added support for variants of i945G, Q35, G31/G33, G84, G92, G96, GT200, G86M, G84M, C79
- Improved RV770 and GT200 detection code
- Updated NVIDIA temperature reading code
- Fixed updater getting stuck during refresh
- CrossFire on Vista64 now reported with note "unsure", instead of just "unknown"
- Added mini graph to sensors
- Screenshots are uploaded as PNG now
- Added crash report error handler
- Updated G70 number of ROPs
- Added PCI Vendor Point of View
- Improved S3 Chrome 400, S20, S18 and S8 detection
GPU-Z 0.2.3 ready for download
- Fixed NVIDIA GeForce GTX 260/280 (GT200) support. Everything is working and tested now
- Removed bogus 190°C PCB temp sensor on various NVIDIA cards
- Added fan speed monitoring for NVIDIA
- Fixed crash when switching devices during sensor refresh
- Fixed ROP/Shader count on NVIDIA G72
- Fixed graphs spilling over their client area
- Fixed a number of other rare crashes
- NVIDIA device ID 0x00F3 now correctly recognized as NV43
- Improved crash reporting module
  • 3 weeks later...
GeForce 177.41 WHQL drivers released
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, and OpenGL, including 3-way SLI Technology with GeForce GTX 280 and GeForce GTX 260 GPUs
- Adds support for CUDA Technology (Vista only)
- Adds support for Folding@home distributing computing application.
- Supports HybridPower, a Hybrid SLI Technology, on the products mentioned above (Vista only)
- Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software
- GeForce 177.41 WHQL (Windows XP 32bit)
- GeForce 177.41 WHQL (Windows XP 64bit)
- GeForce 177.41 WHQL (Windows Vista 32bit)
- GeForce 177.41 WHQL (Windows Vista 64bit)
GPU-Z 0.2.5 Ready for download
Fixed BIOS Reading on HD 4870. Please do not flash non-128K BIOSes to GDDR5 cards
- Fixed GDDR5 bandwidth calculation
- Fixed texture fillrate on RV770 and RV730
- Added three extra on-die temperature sensors to RV770 monitoring
- Removed states.dmp file creation
- Fixed GPU activity readings on RV770
- Changed devices list order to be more intuitive (by bus number now)
- Added Shared Memory support, see the forum for more info
- Fixed more 190°C PCB readings on NVIDIA
- Catalyst Beta versions no longer displayed as version 2.2
- Fixed sensor graph overflow
- Sensor graphs will try to autoscale now
- Fixed RV505 process size
- Fixed memory bus width reading on some ATI RS300
- Fixed rare crash when reading NVIDIA sensors
- Fixed GDDR3 detection for G71
  • 3 weeks later...
GPU-Z 0.2.6
Added full support for HD 4870 X2
- Added support for reading clocks on newer ATI drivers (R700)
- Fix for realtime clock sensor showing double memory speed on RV770 GDDR5
- Added detection for GeForce 9800 GT, GeForce 9300 GE
- Added support to start GPU-Z minimized (use -minimized)
- Added tray icon when GPU-Z is minimized
- Fixed crash when uploading large BIOS files
- Fixed rare crash that could happen on some NVIDIA cards
- Added detection for Intel Q43. G45 and some variants of G35, G965, GM965
Daemon Tools 4.30 Pro & Lite versions released
Lite
- Updated and improved images engine
- Adware free
- Languages updates
- Some minor GUI bugs fixed
Pro
- Redesigned user interface
- Speed optimization
- Ability to burn images onto physical CD/DVD/HD DVD/Blu-ray discs (for Advanced version)
- Erase rewritable discs
- File Associations for supported images
- Blu-ray and HD DVD devices supporting
- Image topology information dialog
