Cpu-Z 1.44 :T:
* Preliminary support for VIA Isaiah processor.
* Support for all VIA Model D processors: VIA C7-M, VIA C7-D, VIA Eden, VIA Eden.
* Memory timings on Intel 5400A/B MCH (Skulltrail).
* Fix AMD Phenom detection issue on Windows Vista 64.
  • Replies 748
VirtualBox v1.5.6
Πρόγραμμα εικονικών υπολογιστών ανοιχτού κώδικα
innotek VirtualBox is a family of powerful x86 virtualization products for enterprise as well as home use. Not only is VirtualBox an extremely feature rich, high performance product for enterprise customers, it is also the only professional solution that is freely available as Open Source Software under the terms of the GNU General Public License (GPL). See "About VirtualBox" for an introduction; see "innotek" for more about our company.
  • 3 weeks later...
CoreTemp 0.97.1
http://www.alcpu.com/CoreTemp/CoreTemp.zip
Version 0.97.1 - 7th March, 2008
- Fix: Phenom did not display proper temperature in version 0.97.
- Fix: Phenom randomly reports 255C (value ignored).
- Fix: Phenom displays more than a single system tray icon per CPU.
- Fix: Phenom 1/4 multipliers rounded improperly.
- Change: C° and F° now will display °C and °F accordingly.
GPU-Z v0.1.8
http://www.techpowerup.com/downloads/1029d/GPU-Z.0.1.8.exe
* Fixed SLI detection for Vista32 and Vista64
* Added automatic refresh of clocks and multi GPU status
* Added support for NVIDIA Quadro FX Go1400, Quadro NVS 440, GeForce 7350 KE, 7300 GT, 8400 SE, 9800 GX2, 9800 GTX, 9500 GT, 8400, Quadro NVS 140M, 135M, FX 360M, 9300M G, 9500M GS, 8600M GT, 8700M GT, FX 3600M
* Added support for G96
* Added support for ATI FireGL V8600, some RV635 and RV620 variants
* Fixed fan speed monitoring for RV6xx
* Fixed fillrate for 8800 GTS 512
* Fixed some subvendor names
* Fixed shader calculation for M68
* Process size, Die size, DirectX Support will now show "Unknown"
* Fixed crash when no sensors detected
* Fixed NV44 ROP and shader calculation
* Fixed crash when NVIDIA BIOS couldn't be read
* Added Splash screen
