Θα προσπαθήσουμε να συμμαζέψουμε την βάση από τις καλημέρες και σήμερα το απόγευμα θα προχωρήσουμε σε αναβάθμιση. . . ×
  • Replies 748
Memtest+ 1.65
*** Enhancements in v1.65 : ***
* New Features
o Add support for Intel Conroe/Merom/Woodcrest
o Add support for Intel Yonah (0.65nm)
o Add support for Intel Presler (0.65nm)
o Add support for B-Step Smithfield
o Add support for ALi/ULi 1689 & 1695
o Add support for ATi RS482
* Bug Fixes
o Solve some P4 detected as Pentium D
o Solve a bug with RAS detect on i955X
o Solve a bug with K5 L1 detection size
o Cosmetic : Mhz changed to MHz
o Rewrite some code to avoid warning with gcc 4
o Solve Fedora bugzilla Bug #162373
http://www.memtest.org/#downiso
Link to comment
Share on other sites
  • 1 month later...
Νεο ClockGen σε Beta ακομα βεβαια....kai ετσι δεν εχουν προστεθει ολα τα διαθεσιμα PLL's..δεν θα χρειαζομστε πια 15cg για καθε μητρικη που εχουμε....αλλα 1!!!:)
http://www.cpuid.com/download/ClockGen.zip
Link to comment
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
SIW - System Information for Windows.
This program perform computer configuration analysis and diagnostics. It gives detailed information about your computer properties and settings, detailed specs for CPU, motherboard, chipset, BIOS, CPU, PCI/AGP, USB and ISA/PnP devices, memory, monitor, video card, disk drives, CD/DVD devices, SCSI devices, S.M.A.R.T., ports, network cards, printers, operating system, installed programs and hotfixes, processes, services, serial numbers (CD keys), users, open files, system uptime, network, network shares, as well as real-time monitors for CPU, memory, page file usage and network traffic. It displays currently active network connections, passwords hidden behind asterisks, installed codecs, and more.
This program also creates a report file, and is able to run in batch mode.
A standalone tool that does not require installation - one less installed program on your PC as well the fact that you can run the program directly from a USB flash drive.
http://www3.sympatico.ca/gtopala/about_siw.html
Link to comment
NIBITOR 2.6a
Main features
Detailed BIOS information output
Device ID
BIOS Version
BIOS Date
Vendor
Core/Memory Clock display
2D Core/Memory Clock
3D Core/Memory Clock
Throttling Core/Memory Clock
Core Voltage display
2D Voltage
3D Voltage
Throttling Voltage
Memory Timings display
Product Identification
Ability to modify the several BIOS Parameters
Core Clock defined within the BIOS
Memory Clock defined within the BIOS
Core Voltage defined within the BIOS
Memory Timings defined within the BIOS
Temperature Settings defined within the BIOS
Fan Speed Settings defined within the BIOS
Specific Boot Settings
Graphics Card OEM and Advanced Signon Message
Monitor Specific Parameters
Graphics Card Initiation Settings
TV Mode Selection (NTSC/PAL)
Ability to check BIOS Integrity
BIOS Checksum Checking
BIOS Structure Checking
Changes in this Version
Added support for GeForce 6600 LE AGP
Added support for GeForce 6800 GS AGP
This new version is build upon the logic of the previous version, with some minor fixes and a redesign of the Unknown devices support... As always for extra features, settings and support please provide us your Original BIOS.
http://www.mvktech.net/component/option,com_remository/Itemid,0/func,download/filecatid,1493/chk,5d35d9823ec8f92422b7d54bb58fd867/
Link to comment
  • 3 weeks later...
Ati tool 25 beta 14
http://www.techpowerup.com/downloads/259
- Fixed crash on X1900 when entering settings under high 3D load
- Show messagebox with explanation and link when user clicks on dump bios button on x1000
- Disabled saving stuff to default profile for Gamma, Mem, Fan. Default profile is default and not a custom setup
- Added support for many ATIGL GPUs
- Fixed "do you want to disable ati clock service" warning not saving "do not ask me again"
- Added Gamma for X1000 Series
- Changed rendering so that there is no more lag when not scanning. during scans this might still be possible, to maximize heat output
- Fixed issue where the renderer would not initialize properly if running on secondary adapter
- Bug where ATITool was never picking up artifacts fixed
Link to comment
καινουργιο S&M 1.8.0 alpha
τωρα και με test για σκληρους......οι κοσμοσφαιρες ξαναρχονται. :jump:
download
Καποια μαμακια γινεται με το λινκ....απλα αν εχετε προβλημα πατηστε με το ποντικι πανω στην διευθυνση και μετα πατηστε Enter..
Link to comment
Αρχική απάντηση από deadlock7 [Σήμερα, στις 03:22]
Το link οπως ειπες δεν λειτουργει.Επειδη ομως δεν το βρισκω ουτε στην επισημη σελιδα κρατω καποιες επιφυλαξεις..
Τσάκω το
http://rapidshare.de/files/14717286/snm_1.8.0a.rar.html
Link to comment
