PGM Μάρτιος 25, 2005 #221 Μάρτιος 25, 2005 Windows x64 Science Benchmark Released Official Page 2 FINAL 32 Bit: This is the 32 Bit Final Version dated March 21st 2005Download 2 FINAL 64 Bit: This is the 64 Bit Final Version dated March 21st 2005Download-64-bit support for Windows x64 edition--------------------------------------------Important notes for 64-bit support.: 64-bit is a beta version at the moment.: Performance may change in the future depending on how we tune for fp performance. You should see significant speedups on both EM64T and AMD64 processors in 64-bit mode. Part of this is due to compiler improvements. : Intel EM64T systems are supported, however, ScienceMark2 won't be able to detect them properly in MemBench.This will be remedied in a future version.: CipherBench is not supported in 64-bit mode. Running AES returns an incorrect result, that is impossibly too fast.This will be remedied in a future version.: Both SGEMM and DGEMM benchmarks are restricted to compiler only under 64-bit edition.This will be remedied in a future version.: There are several new memory cores that are present in the 64-bit build of Membench that are not present in 32-bit edition.This is due to the new ISA.: STREAM is tweaked a bit Link
enduracell Μάρτιος 26, 2005 Author #222 Μάρτιος 26, 2005 CPU-Z 1.28Support for SiS chipsets improved : 648FX, 649, 655FX, 655TX, 656.Support for nVidia nForce4 SLI Intel Edition.Support for Intel Pentium D, Pentium XE, AMD Turion, Opteron 252.New F7 key to simplifiy the creation of the validation fileNew forum.
deadlock7 Μάρτιος 28, 2005 #224 Μάρτιος 28, 2005 Central Brain Identifier version 7.4.0.5 Build 0323 Final Latest Changes: * Realized full identification of the newest mobile AMD Turion 64 MT/ML series processor * Added support to Winbond W83627EHF è W83637HF chips to sense the VCore and CPU temperature * Added complete recognition of the AMD Opteron processor based on Athens, Troy and Venus cores * Added determination of rare processor models of the AMD Athlon XP 2900 and Athlon 64 3300+ CPU * Added algorithm to determine and unlock the protection to FID transition of AMD K7 processors * Added showing information on Super I/O chip concerning vendor name, chip model and its version * Realized specifically optimized algorithm to sense the VCore and CPU temperature using ITE chips * Added determination of the maximum work temperature and diode offset of the AMD64 processor * The formula which calculates a P-Rating for the processor now supports many newest AMD64 CPUs * The specific information on the AMD64 CPU has been enhanced and moved to the Controller tab * Added method to identify the Package and Proc.Technology when AMD64 CPU isn't fully recognized * Added determination of the whole HT Link frequency range supported by the AMD64 processor * Fixed a bug in the HT Link revision determination, added revision of the HT Link I/O Specification * Fixed the bugs when setting new DRAM timings for the VIA KT400A and VIA KT600 chipsets
enduracell Μάρτιος 28, 2005 Author #225 Μάρτιος 28, 2005 Memtest86+ V1.55EnhancementsAdded support for Intel E7221Added support for nForce 4 Intel EditionAdded detection for ATi Radeon Xpress 200Added ECC polling for Intel E7221Bug FixesMore precise detection of K8 Memory Freq.Some minor bug fixes.
enduracell Απρίλιος 2, 2005 Author #226 Απρίλιος 2, 2005 Stress Prime 0.30bug report and testing from Bryan Kiilerich Levinsky - SP2004 now works on CPUs with Data Execution Prevention (DEP)/NX-bit/XD-bit enabledmove Prime95 assembly code into code segmentCentral Brain Identifier 7.5.0.0 Build 0330 R1full identification of dual-core AMD Opteron processors (models x60, x70 and x75)detection of the newest Revision E6 and Socket940 OuPGA packagepreliminary identification of AMD Athlon 64 X2bugfixes, etc.
PGM Απρίλιος 5, 2005 #227 Απρίλιος 5, 2005 PowerStrip 3.59 Version: 3.59 Released: 31 March 2005 File size: 1.17 MB Download
deadlock7 Απρίλιος 8, 2005 #228 Απρίλιος 8, 2005 Δεν ξερω αν πρεπει να το βαλω,αλλα καλο ειναι να υπαρχει...(original post απο το forum του prime95 : http://www.mersenneforum.org/showthread.php?t=3934)Early Beta of version 24.11 Version 24.11 has two major improvements.1) There is a 64-bit version for 64-bit Windows. It contains all new faster factoring code.2) An Athlon64 optimization was found for both the 32-bit and 64-bit versions of prime95. You'll get about a 15% performance boost. Still not as fast as a similarly clocked P4, but it is much closer.Only AMD64 machines should try this version. It is not well QA'ed. Save your work before installing, just in case there is a problem.You can download from:Windows: ftp://mersenne.org/gimps/p95v2411.zipWindows 64-bit: ftp://mersenne.org/gimps/p64v2411.zipWindows NT service: ftp://mersenne.org/gimps/winnt2411.zipLinux: ftp://mersenne.org/gimps/mprime2411.tar.gzLinux (static link): ftp://mersenne.org/gimps/sprime2411.tar.gz
.38-.45 Απρίλιος 9, 2005 #229 Απρίλιος 9, 2005 το CPU-Z 1.28.2 διαβαζει σωστα τους διαρετες, ή το εκανε και πιο πριν και δεν το πηρα εγω χαμπαρι;
chroma Απρίλιος 12, 2005 #230 Απρίλιος 12, 2005 Αν βαρεθήκατε το panel της nvidiawww.nhancer.comυ.γ. απαιτεί .net framework 1.1
enduracell Απρίλιος 14, 2005 Author #231 Απρίλιος 14, 2005 Speedfan 4.23added full 64 bit support for AMD64 systemsadded full support for ATI SB300 SMBus added full support for FINTEK F75375S added chinese translation completely rewritten the installer to handle the new services properly initialized PortIO object when running under Win9x removed a test related to LPC47N252 that caused some systems to freeze fixed W83627EHF fan speed readings added full support for NATIONAL SEMICONDUCTOR LM99 and LM63
GoriLLakoS Απρίλιος 16, 2005 #232 Απρίλιος 16, 2005 http://www.geocities.co.jp/SiliconValley-Oakland/8259/ mobile meter συχνοτητα θερμοκρασια wattage.... δεν ξερω αν το εχετε ξαναποσταρει.... δουλευει μονο σε φορητους...σε desctop cpus απλα δειχνει συχνοτητα....
enduracell Απρίλιος 17, 2005 Author #233 Απρίλιος 17, 2005 NiBiTor v2.1Added option to edit all 8 timingsets of GeForce 6 cardsAdded support for: Quadro FX Go1400Quadro FX 1300 PCI-EGeForce FX5700 VEFixed Go6800 BIOS issuesFixed BIOSes with device type "NVIDIA PCIE-E 6800 Series GPU" Various bugfixes
enduracell Απρίλιος 17, 2005 Author #234 Απρίλιος 17, 2005 EVEREST Home Edition 2.0 Beta Build 312identification of Athlon 64 (aka Venice), Athlon 64 X2 (aka Toledo), Opteron 1xx (aka Venus), Opteron 2xx (aka Troy), Opteron 8xx (aka Athens), DualCore Athlon 64 (aka Toledo), DualCore Opteron 1xx (aka Denmark), DualCore Opteron 2xx (aka Italy), DualCore Opteron 8xx (aka Egypt), Xeon (aka Irwindale) and Xeon MP (aka Potomac)basic chipset information for Intel Profusionextended chipset information for ATI RS480(M), identification of DDR2-1000 memory modulesGPU information for Matrox Parhelia-LX PCI-EnVIDIA NV42SiS 315 Family and VIA UniChrome Pro, bugfixes, and much more!RMClock Utility 1.5more configurational options for AMD K8Transmeta LongRun Technology supportindependent AC and Battery performance/power profilesminor improvements, etc Nero CD-DVD Speed V3.80Create Data Disc: added support for ISO files Bitsetting: added support for certain AccessTek drives Added MID/ATIP code to saved HTML file Added option to include MID/ATIP code with filename Improved layer break detection for recordable DVDs Disc Quality testAdded recorder information for DVD-R/DVD-RW discs which have not been burned with the Create Data Disc function Added quality score algorithm for certain drives Small improvements and bug fixes
GoriLLakoS Απρίλιος 28, 2005 #235 Απρίλιος 28, 2005 Το cpu-z 1.28 ver download ulr απο την database των tools δεν λειτουργει....Not FoundThe requested URL /download/cpu-z-128.zip was not found on this server
PGM Απρίλιος 28, 2005 #236 Απρίλιος 28, 2005 Αρχική απάντηση από Βασιλης [Σήμερα, στις 16:55] Το cpu-z 1.28 ver download ulr απο την database των tools δεν λειτουργει....Not FoundThe requested URL /download/cpu-z-128.zip was not found on this server Διορθώθηκε
deadlock7 Μάϊος 16, 2005 #237 Μάϊος 16, 2005 Ενα πολυ καλο προγραμμα για τη σταθεροτητα του συστηματος μας ειναι το OCCT.Αρκετοι το χρησιμοποιουν στο εξωτερικο και δεν εχουν ακουστει προβληματα(πχ Prime95).Μπορειτε να το κατεβασετε απο εδω http://www.ocbase.com/OpenBeta/OCCTv0.91.exe
PGM Μάϊος 17, 2005 #238 Μάϊος 17, 2005 PowerStrip 3.60 Version: 3.60 Released: 14 May 2005 File size: 1.17 MB
greekfragma Μάϊος 20, 2005 #239 Μάϊος 20, 2005 ΝΕΟ SPEEDFAN- enabled GET CONFIG button on the INFO tab (please, read the help file) - added support for ALi M1563 SMBus with M1681 - enabled online GET CONFIG procedure to download user supplied configurations for individual motherboard models - fan names set up by sensor's initialization code are now properly reflected in the UI - better detection of ITE IT8702F - identified a new revision of ITE IT8705F - added debug code and improved NS PC87366 support - fixed russian and added danish translation - Winbond W83791D and W83791SD do share the same Device ID and are now always detected as a Winbond W83791D - properly closed the I/O support routines when entering suspend http://www.almico.com/installspeedfan424.exeenjoy:flower:
unseen Μάϊος 20, 2005 #240 Μάϊος 20, 2005 To systool ειναι ενα κορυφαιο προγραμματακι. Οποιος θελει ας ριξει μια ματιαhttp://www.techpowerup.com/systool/latest.php
